1 Reply Latest reply on Dec 5, 2014 12:25 PM by pixxxel schubser
    tab leaders in tables
    VeluVK Level 1
      Anyone please suggest my code errors?
      I need the leader dots in every first column of all the tables. tabs need to be stop before 6pts of the column width.
      var myTable = myDoc.stories.everyItem().tables.everyItem().getElements();
      for(t=0; t<myTable.length; t++)
          var col = myTable[t].columns[0].select();
          var myFirstColumn = myTables[t].columns[0].width;
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findGrepPreferences.findWhat = "(.+)$";
          found = app.selection[0].findGrep (true);
      for (i = 0; i < found.length; i++)
        found[i].insertionPoints[-1].contents = "\t";
        TabStops.position = myFirstColumn - "6pt";
      The code shows the below error.
      Regards,
      Velu
        • 1. Re: tab leaders in tables
          pixxxel schubser Level 5
          Hi VeluVK,
          I'm not sure if I understand you right.
          And I'm sure there are better possibilities to do what you want.
          But with this little changes your code will run:
              //var myFirstColumn = myTables[t].columns[0].width;
              var myFirstColumn = myTable[t].columns[0].width;
            //found[i].insertionPoints[-1].contents = "\t";
            //TabStops.position = myFirstColumn - "6pt";
            found[i].tabStops.add( {position:myFirstColumn - 6});
          Remember – I'm not an InDesign scripter.
          Have fun
