2 Replies Latest reply on Apr 24, 2008 10:43 AM by eLearning_Developer
    Wonky Demo Output - Misaligned Text Boxes and Jumpy Mouse
    eLearning_Developer
      Hello All,
      I'm using Captivate 3 to record a demo of an internal organization's web-based system. As I'm recording I immediately noticed that the mouse gets very jumpy and fades in and out whenever I try to scroll up/down or side to side. It takes it approximate 4-8 seconds to "catch up" and reappear on the demo recording screen. It creates a chopping appearance.
      Once I view the recorded demo, the mouse appears to be trailing and creating weird lines (they fade after 3 seconds or so) along the path the mouse previously traveled. Additionally, the auto caption and highlight boxes are totally misaligned with the various links I selected during the demo. Has anyone else seen these same issues and maybe figured a way to fix them? Could it simply be a matter of changing some global recording settings? Any suggestions?
      Thanks for your help!
        • 1. Re: Wonky Demo Output - Misaligned Text Boxes and Jumpy Mouse
          jojolina Level 1
          Hi eLearningDeveloper and welcome to the community.
          I think the problem might lie in the time to capture vs the time to load. To clarify, when you click on a screen, Captivate reacts almost instantly in recording what is on your screen at that time. Unfortunately, since you are capturing off a server (web based system), your screen takes a while to refresh, thus Captivate is recording "incomplete" pages. My suggestion is to use a manual capture method in cases like this i.e PrtScrn to capture your screenshots and manually sart and end Full Motion Recording for drag&drop type of capture The keys used are customisable at Edit/Preferences under the Recording node.
          Lastley, work slowly thus allowing full screen refreshing at each stage.
          Hope this helps.
          Andrew
          PS On another subject, try not to save your cp files to the company server as this could lead to file corruption issues, rather save to the standalone PC.
          • 2. Re: Wonky Demo Output - Misaligned Text Boxes and Jumpy Mouse
            eLearning_Developer Level 1
            Hello Andrew,
            Thanks very much for the helpful suggestions!
            Monica
