5 Replies Latest reply on Mar 9, 2007 5:02 AM by Newsgroup_User
    Sound Object
    Arunkkumar2207j
      Can we load sound dynamically without playing...........
        • 1. Re: Sound Object
          Level 7
          Arunkkumar2207j,
          Yes.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Sound Object
            prafulka
            Try this may be solve your problam
            var myNumber:Number = new Number();
            var the_sound:Sound = new Sound();
            the_sound.onLoad = function(success:Boolean) {
            var totalSeconds:Number = this.duration/1000;
            trace(this.duration+" ms ("+Math.round(totalSeconds)+" seconds)");
            var minutes:Number = Math.floor(totalSeconds/60);
            var seconds = Math.floor(totalSeconds)%60;
            if (seconds<10) {
            seconds = "0"+seconds;
            trace(minutes+":"+seconds);
            the_sound.loadSound("yoursound.mp3", true);
            stop_btn.onRelease = function() {
            trace("sound stopped"+the_sound.duration);
            myNumber = Math.round(the_sound.position/1000);
            the_sound.stop();
            play_btn.onRelease = function() {
            trace("sound started"+the_sound.duration);
            the_sound.start(myNumber);
            • 3. Re: Sound Object
              Arunkkumar2207j Level 1
              Thanks "David",
              Purpose is Player should play one song from playlist and download next without playing, so that buffering times is reduced.
              • 4. Re: Sound Object
                Thank You i have completed my task to some extend.
                • 5. Re: Sound Object
                  Level 7
                  Arunkkumar2207j,
                  > reduced.
                  Take a look at the Sound.load() method; you'll see that the second
                  parameter is optional and defaults to false. When that parameter is set to
                  false, the MP3 file loads, but does not begin playing until you invoke
                  Sound.start(). You can check the value of Sound.getBytesLoaded() against
                  getBytesTotal() repeatedly -- such as in a setInterval() loop -- to
                  determine how far along the sound has loaded; or react to the
                  onSoundComplete event.
                  David Stiller
