2 Replies Latest reply on Dec 6, 2014 9:04 AM by Picmention Matthias
    Logo vibrates to music
    Audio Reacting Image
      I want to know how to make the logo vibrate to the music. I know how it gets big but I just wanna know what the effect is called in  after effects to make it vibrate. I know how to hook it up with key frames btw Video- https://www.youtube.com/watch?v=AhF8NLUQfTQ
        • 1. Re: Logo vibrates to music
          aloooy_10 Level 1
          As I know you can create an audio reaction animation with 3 effects only :
          Audio waveform
          Audio Spectrum
          Trapcode Form
          This might help you as I guess , If I missed your point then clarifide it to me.
          • 2. Re: Logo vibrates to music
            Picmention Matthias Level 1
            You can create keyframes from Audio.
            First go to animation->keyframe assistant->create keyframes from audio. These Keyframe values can be used now on every effect you want by using expressions.
            Example 1:
            thisComp.layer("Audioamplitude").effect("Linker Kanal")("Schieberegler")
            Example 2:
            temp = thisComp.layer("Audioamplitude").effect("Linker Kanal")("Schieberegler");
            the first example uses the audiopeak-value directly (be careful I uses AE in german, I don't know if copy&paste works with other languages), the second one uses the linear-effect to remap your values to a value between 0 and 100. This is usefull when using it for transparency. The four values 0,30,0,100 can changed by you.
            0 = smallest audiopeak Value
            30 = highest audiopeak Value
            0 = smallest output
            100 = highest output
            Best Regards
