11 Replies Latest reply on Dec 9, 2014 8:14 AM by A.T. Romano
    Susie Mylov
    Hello: I speak bad Englis
      Hello: I speak bad
      English
      , SO I get a friend
      to call, I have also sent you some paper letter,
      .as I have translated in Google / translate and sent you
      by. POST DENMARK,
      but unfortunately has not answered
      me by. paper letter
      ?? ?? Both my
      father and I have PHOTO SHOP ELEMENTS11
      & my father also
      PHOTOSHOP PREMIERE, we can easily
      use Photoshop PREMIERE & read our MINI
      DV tape into PREMIERE,
      and make signs
      with text
      & burn it onto a DVD disc but when we play the
      DVD
      in a blue ray DVD player so pixilere
      the / &
      interruptions in the sound several
      places
      ?? What are we doing
      wrong ?? do you
      have any
      GOOD advice ?? to what we can do ?? for example.
      sikrerhed burn DVDs
      ?? how security
      you burn a DVD in
      PHOTOSHOP / PREMIÆRE
      ?? can you
      explain to my friend that quiet &
      quiet so she can write
      it down
      Greetings from. Susie
      Mylov
        • 1. Re: Susie Mylov
          A.T. Romano Level 7
          Susie Mylov
          This is not Adobe. This is the Adobe Premiere Elements user to user forum that you have reached by posting your thread. So, we do not have
          any letters that you may have sent to Adobe about your Elements 11 questions.
          What do you record with your miniDVD camcorder - DV standard (4:3) or DV widescreen (16:9). For now let us assume DV standard (4:3).
          Open Premiere Elements 11 Expert workspace, go to File Menu/New/Project and Change Settings.
          In Changes Settings, set the project preset to agree with your source (in this case DV standard (4:3) - so you select
          PAL
          DV
          Standard
          Before you get back to the Expert workspace, in the new project dmake sure that you have a check mark next to "Force Selected Project Setting on this Project".
          Then do Add Media/DV Camcorder to get your DV data as DV AVI standard on the Timeline of your project for editing.
          When you are ready to burn to disc, then
          Publish+Share
          Disc
          DVD disc
          with preset set at PAL_Dolby DVD.
          Have you gone through those details to produce you PAL DVD-VIDEO format on DVD disc?
          Let us start with the above and then decide what next.
          Thank you.
          ATR
          Add On...do not worry about the language....we will overcome any language problems as well as Elements problems...if you do not understand anything that I write, just let me know, and I will re-write.
          • 2. Re: Susie Mylov
            A.T. Romano Level 7
            Susie Mylov
            Please continue your comments in this thread so that we have all your information in one thread. You have now started a new thread to continue
            the discussion already started.
            You need Premiere Elements to burn to disc. Photoshop Elements cannot be used by itself to create the DVD-VIDEO on DVD disc that will be
            required to DVD player.
            The way that you set up your Premiere Elements project influences how the end product will look like.
            So we need to go into the details of what you are doing.
            Did you set up your project as I have suggested and did you get the same pixelated end product when viewing it on your player?
            ATR.
            • 3. Re: Susie Mylov
              A.T. Romano Level 7
              In your other thread you wrote
              Susie Mylov Denmark
              Hello Again. we
              can easily
              burn a DVD, but when we play it on
              a
              BLUE RAY player picks the
              sound & picture
              pixilere why does
              it do that
              ?? & Then it stops COMPLETELY playing DVD disc
              ?? can you tell us whether we PHOTO SHOP
              ELEMENTS can create a safety burning ??
              SO we avoid the
                picks the sound
              & picture pixilere
              Again, easily enough to burn to DVD, but you must setup the project (import, edit, and burn to)
              correctly to get the best results. The information that is needed to setup the a project includes
              a. properties of what you are putting on the Premiere Elements timeline
              b. project preset that you select
              c. editing
              d. burn to details
              When you use a program such as Premiere Elements 11 often you have to set the project preset yourself
              rather than let the project do it for you.
              Please go through the workflow that I posted in post 1 and let us know if you get the same pixelated results when
              you view your DVD-VIDEO on DVD with your player.
              Thank you.
              ATR
              • 4. Re: Susie Mylov
                2 duplicate message threads locked
                Susie Mylov - DVD Problem
                Susie Mylov ?2
                • 5. Re: Susie Mylov
                  The Elements Tutorial Links Page http://forums.adobe.com/thread/1275830 may also help
                  https://translate.google.com/ to help with translations
                  • 6. Re: Susie Mylov
                    Hello: I speak bad Englis Level 1
                    We use firewall entry
                    & cable plugged
                    into the
                    firewall entry when we play minn / DV
                    TAPE into the PC,
                    but ANYWAY pixilere
                    image / &
                    sound stutters when
                    they are burned and played in a BLUE RAY
                    player ?? you can
                    choose
                    the safe burning of DVD ??
                    MVH Susie Mylov
                    • 7. Re: Susie Mylov
                      & cable plugged
                      into the
                      TAPE into the PC,
                      but ANYWAY pixilere
                      image / &
                      sound stutters when
                      player ?? you can
                      choose
                      MVH Susie Mylov
                      • 8. Re: Susie Mylov
                        A.T. Romano Level 7
                        Susie Mylov
                        What did your mini camcorder record
                        DV data 4:3 Standard
                        or
                        DV data 16:9 Widescreen
                        OR
                        Did you do instead HDV data capture firewire into Premiere Elements 11?
                        Again, the end results (good or bad) are influenced by how you set up the project.
                        So, if you recorded DV data 4:3 Standard
                        Did you set the project preset to PAL DV Standard and use Add Media/DV Camcorder before you started the firewire capture?
                        If you recorded DV data 16:9 Widescreen
                        Did you set the project preset to PAL DV Widescreen and use Add Media/DV Camcorder before you started the firewire capture?
                        If you record HDV data,
                        Did you set the project preset to PAL HDV HDV 1080i25 and use Add Media/HDV Camcorder before you started the firewire capture?
                        If your input into the project situation is bad, that must be made good before we get to the burn to disc matters.
                        As a control, can you do a capture firewire from your miniDV camcorder into a program such as Movie Maker without the type of issues that you are having with Premiere Elements 11?
                        Please consider and let us know if our comments are being understood.
                        Thank you.
                        ATR
                        • 9. Re: Susie Mylov
                          Hello: My camcorder is brand SONY & is from about years. 2003, we assume that my camcorder is set to record in 4/3 format ?? how we look on the camcorder I have records in 4/3 format ??
                          MVH From
                          Susie Mylov
                          Denmark
                          • 10. Re: Susie Mylov
                            You have the camera, so look in the user manual or the screen menu on the camera  itself to see which options you are using
                            • 11. Re: Susie Mylov
                              A.T. Romano Level 7
                              Susie Mylov
                              If you have have a Sony miniDV camcorder and you recorded with the 4:3 setting, then this is what you do to get the DV data from the camcorder and into your Premiere Elements 11 project.....
                              You will be putting PAL DV AVI 4:3 on your Timeline......
                              1. Open Premiere Elements 11 to the Expert workspace.
                              Go to File Menu/New/Project and Change Settings.
                              2. Under Change Settings, set the project preset for
                              PAL
                              DV
                              Standard
                              3. After you do that and click OK, you will see the new project dialog.
                              Make sure that you have a check mark next to "Force Selected Project Setting on This Project" and
                              then OK to get back to the Expert Workspace.
                              4. In the Expert workspace, go to Add Media/DV Camcorder and follow the instruction to begin
                              your DV data capture firewire from the camcorder to the computer/Premiere Elements Capture Window.
                              5. When you go to create your PAL DVD-VIDEO 4:3 on DVD disc, then use
                              Publish+Share
                              Disc
                              DVD disc
                              with the preset for PAL_Dolby DVD.
                              If you go to burn your 4:3 Timeline to 16:9 (for PAL DVD-VIDEO Widescreen or Blu-ray disc format on Blu-ray disc),
                              then we need to talk some more since it is not good going from 4:3 source to 16:9 end product without further
                              considerations.
                              Please read the above and let us know if that is the information that you need to move forward with your project.
                              Thank you.
                              ATR
                              • 12. Re: Susie Mylov
                                A.T. Romano Level 7
                                John
                                Susie Mylov has already given us this information when written miniDV camcorder and 4:3.
                                ATR
