0 Replies Latest reply on Feb 28, 2007 11:39 PM by kptgreg2
    nested movie clip will not repeat
      I am creating a mp3 player that gets info from an external XML file. I am trying to create a masked scrolling message that gets the text data from the XML file. I have succeeded doing this and was very happy until I found out the message only scrolls once. I do not understand why it doesn't loop.
      The message is loaded into a movie clip called prompt_mc that has a dynamic text field named prompt_txt inside of it. In prompt_mc I moved the message across 200 frames from right to left and then I dropped the prompt_mc on the main timeline with a mask object above it. The mask is handled in the code and works great. Anyone know why my prompt_mc is not looping or have any ideas??
      Here is part of my code if it's helpful:
      // function to check if XML file is loaded and parse XML file
      function loadXML(loaded) {
      if (loaded) {
      _root.prompt = this.firstChild.childNodes[1].firstChild.nodeValue;
      _root.songtitleone = this.firstChild.childNodes[2].childNodes[0].firstChild.nodeValue;
      _root.artistfirstSong = this.firstChild.childNodes[2].childNodes[1].firstChild.nodeValue;
      prompt_mc.prompt_txt.text = _root.prompt;
      songtitleone_txt.text = _root.songtitleone;
      // prompt message mask
      // play songs
      var artistSong:String = _root.artistfirstSong;
      controller.autoPlay = false;
      play_mc.onRelease=function() {
      if (this._currentframe == 1) {
      else {
      } else {
      trace("Error: file not loaded!");
      // load XML file and define XML object
      xmlData = new XML();
      xmlData.ignoreWhite = true;
      xmlData.onLoad = loadXML;
