1 Reply Latest reply on Dec 6, 2014 7:33 AM by A.T. Romano
    ムービーメニューのメインメニュータイトル・シーンメニューの文字レイアウト保存不具合
    田戸
      入力・保存後、DVDにはそのまま反映され書き出しができますが、編集のため再度開くとメインメニュータイトルとシーメニューの文字レイアウトがくずれてその都度編集・設定しなくてはなりませ ん。
      メインメニュータイトルは改行していると入力していないアルファベット英数文字が勝手に挿入・保存されてしまいます。
      (文字は入力されたものがそのまま残ってはいますが・・・)
      DVDに書き出しの都度、文字レイアウトをやり直さなければならず大変不便です!
      これはバグか購入したソフトの不具合と思われますので、誠意あるメーカーの改善対応を至急お願いします。
        • 1. Re: ムービーメニューのメインメニュータイトル・シーンメニューの文字レイアウト保存不具合
          A.T. Romano Level 7
          This is not Adobe. Rather a user to user forum.
          What version of Premiere Elements are you using and on what computer operating system is it running?
          Do you have this menu problem with all your menus and projects or is the problem with one menu and one particular project?
          What is the project preset that you set (manually) or that the program set (automatically) for this project?
          What are the properties of your source media? How many Timeline menu markers are you placing and have you left a few frames between each so
          that you do not have a marker essentially on top of another?
          What is the name of one of the disc menus involved in the problem? Does the thumbnail for the menu have "HD" in its upper right corner?
          In the disc menu customization area, have you made sure that you do not have any overlapping buttons (red lines representing
          overlap)?
          To make sure that some settings have not been corrupted, let us delete the Adobe Premiere Elements Prefs file, and, if necessary, the whole folder
          in which it exists. If you supply the necessary details (Premiere Elements version and computer operating system), I can tell you how to find and delete this file or that folder.
          We will be watching for your follow up with details.
          Thank you.
          ATR
