15 Replies Latest reply on Jan 14, 2015 3:53 PM by A.T. Romano
    Adobe Premiere Elements 13 Deactivation ?
    Exacct
      How Deactivation Adobe Premiere Elements 13 ?
      Thank You........  Very, very much
        • 1. Re: Adobe Premiere Elements 13 Deactivation ?
          A.T. Romano Level 7
          Exacct
          Premiere Elements 13 Expert workspace, Help Menu, Sign Out.
          Please let us know if that works for you.
          Thank you.
          ATR
          • 2. Re: Adobe Premiere Elements 13 Deactivation ?
            Exacct Level 1
            This metod is not good, but thank You
            • 3. Re: Adobe Premiere Elements 13 Deactivation ?
              A.T. Romano Level 7
              Exacct
              That is the way you deactivate Premiere Elements 13.
              In what way is it not good?
              Please explain.
              Thank you.
              ATR
              • 4. Re: Adobe Premiere Elements 13 Deactivation ?
                Exacct Level 1
                A.T. Romano
                Hi,  I try do it now, I will explain some later
                Thank You so much.
                Have you a good evening...
                • 5. Re: Adobe Premiere Elements 13 Deactivation ?
                  Exacct Level 1
                  Yesterday upgraded BIOS and now turned out that Adobe Premiere Elements 13 is already the third computer and can be installed in only two
                  • 6. Re: Adobe Premiere Elements 13 Deactivation ?
                    A.T. Romano Level 7
                    Exacct
                    I am going to try a different approach to try to determine the cause of your issues with deactivating Premiere Elements 13.
                    Do you have a tryout or purchased version of Premiere Elements 13 that you are trying to deactivate?
                    What computer operating system is Premiere Elements 13 running on?
                    When open a new project to the Expert workspace, go to Help Menu/Sign Out, do you see a "Sign Out" option? If you do not,
                    what do you see instead....no mention of Sign In (your email address) or anything related to Sign In or Sign Out?
                    What is your evidence that the program is not already deactivated?
                    Please consider the above and then we can decide what next.
                    Thank you.
                    ATR
                    • 7. Re: Adobe Premiere Elements 13 Deactivation ?
                      A.T. Romano Level 7
                      Exacct
                      Thanks for the reply. Since we both posted at the same time, we did not see the other's comments.
                      If Premiere Elements 13 is now installed and activated on each of two of your computers, you will need
                      to deactivate one of those two in order to install that same purchased serial number on yet another computer.
                      So, on either of those two (already with Premiere Elements 13 installed and activated with this one and only serial number),
                      Help Menu/Sign Out.
                      What is happening so that is not working for you?
                      If you cannot sort out the activation/deactivation situation, the only one who can is Adobe via its Adobe Chat. To do that,
                      please click on
                      Contact Customer Care
                      Premiere Elements
                      Adobe ID, Signing In
                      Adobe ID, Sign In, Account Help
                      Chat Panel
                      If the link does not hold the set, then you will have to navigate to the Chat Panel using the above titles as guides.
                      We will be watching for your progress.
                      ATR
                      • 8. Re: Adobe Premiere Elements 13 Deactivation ?
                        Exacct Level 1
                        A.T.Romano
                        Thank You very....
                        Its Ok, but its one a litle problem, wrote Please insert E drive disk, when I sixth time clik on cansel,cansel,...  than its  ok, but I think its not every Ok, but Program now its working, I hope this is a litle problem
                        • 9. Re: Adobe Premiere Elements 13 Deactivation ?
                          A.T. Romano Level 7
                          Exacct
                          Thanks for the follow up with the good news that the program deactivation matter is taken care of.
                          That No Disk in Drive is a major nuisance issue that has been appearing in several of the threads here lately.
                          1. Make sure you have restarted the computer.
                          2. Do you actually have an E Drive on your computer?
                          What is your drive situation, especially with regard to removable drives?
                          More later.
                          ATR
                          • 10. Re: Adobe Premiere Elements 13 Deactivation ?
                            Exacct Level 1
                            Did you upgrade your computer's hardware, replace a hard drive, upgrade your operating system, or format your computer before deactivating your software?
                            Ask Adobe Support to help you deactivate from a machine you cannot access.
                            Have your serial number or Adobe ID ready, and then contact us.  Where ???
                            Help me pleace !!!
                            • 11. Re: Adobe Premiere Elements 13 Deactivation ?
                              Exacct Level 1
                              That's exactly a problems in desktop:
                              The serial number is already in use by by the maximum allowed computers. You need to deactivate another computer to use this product.
                              • 12. Re: Adobe Premiere Elements 13 Deactivation ?
                                Exacct Level 1
                                I can not acses to my previos  a computers, I thing that I have a big problem with activations
                                My Computer MacBook Pro 13 retina
                                • 13. Re: Adobe Premiere Elements 13 Deactivation ?
                                  A.T. Romano Level 7
                                  Exacct
                                  Lots for us to catch up on.
                                  First old matter...did your Premiere Elements 13 No Disc error return? If it did, there is now an Adobe fix which has been working for most.
                                  The fix is to delete or disable the file name OldFilm.AEX. In Windows 7, 8, or 8.1 64 bit, it is found...
                                  Local Disk C
                                  Program Files
                                  Adobe
                                  Plug-ins
                                  Common
                                  NewBlue
                                  and in the NewBlue Folder is the OldFilm.AEX that you delete or disable by renaming the file from OldFilm.AEX to OldFilm.AEXOLD.
                                  Now with regard to your post where you are asking "Where???"
                                  This sounds like a message to you from Adobe. But Adobe would have given you contact information. Where and how did you get it? Whose name was on the message? I do not see it posted in your thread by Adobe Staff. It sounds like someone with incomplete information to confuse you rather than help you. I did not send it to you. I am not Adobe. If you do not have contact information on the message that you received, then please use
                                  the contact with Adobe Chat that I suggested back in post 7 of this thread. At that time I wrote...
                                  please click on
                                  Premiere Elements
                                  Chat Panel
                                  Please let me know if you are OK with the information that I have just written.
                                  Thank you.
                                  ATR
                                  • 14. Re: Adobe Premiere Elements 13 Deactivation ?
                                    A.T. Romano Level 7
                                    Exacct
                                    I did not see your last few messages of today until after I had posted by reply numbered 13.
                                    You are at a place where Adobe is the only one to sort out your product activation problems. So, please
                                    contact Adobe Chat as I have detailed previously
                                    please click on
                                    Premiere Elements
                                    Chat Panel
                                    Adobe Chat for these activation matters has been very effective - quick and professional. So, it is your best opportunity to be back
                                    to normal within minutes or not much longer than that.
                                    Please let us know what is happening.
                                    Best wishes
                                    ATR
