1 Reply Latest reply on Dec 8, 2014 12:15 AM by CarlosCanto
    Script that gives specific names to layers - from bottom to the top
    memcus
      This is probably an easy one for anyone with JavaScript experience.
      I have 35 layers that I want to give specific names to (now they're named liked "layer 1, 2, 3" - but sometimes this won't be consistent, so some numbering might be skipped,
      in other words I can't rely on a script that renames a specific "Layer 1" to "my name").
      I want to rename each layer from the bottom to the top, i.e.:
      "Power"
      "Yellow"
      "Hello"
      With the script working its way up from the bottom to the top.
      How do I accomplish this?
      Thank you so much for you taking your time to help me.
        • 1. Re: Script that gives specific names to layers - from bottom to the top
          CarlosCanto Adobe Community Professional & MVP
          something like this?
          if so, type your names in a text frame, select it and run this script
          // rename Layers from the bottom up
          // carlos canto
          // https://forums.adobe.com/thread/1653162
          // type your names in a text frame, select it and run this script
          var idoc = app.activeDocument;
          var itext = idoc.selection[0];
          var a_names = itext.contents.split ('\r').reverse();
          var namecount = a_names.length;
          var layercount = idoc.layers.length;
          var counter = Math.min(namecount, layercount);
          for (i=layercount-1, j=0; i>=layercount-counter; i--, j++) {
              var ilayer = idoc.layers[i];
              ilayer.name = a_names[j];
