1 Reply Latest reply on Dec 10, 2014 7:55 AM by Peter DPP
    Broadcast legal levels when downscaling
    Peter DPP Level 1
      Has anyone else experienced any problems when downscaling content from HD to SD prior to delivering to broadcaster.
      Whenever I do it my luma levels get pushed out of broadcast safe, and my spot is rejected. The only workaround I have found is to use Resolve for any downscaling, which is not an ideal solution.
      I on a Mac Pro 5,1, using Premiere Pro CC 2014 2014.1 release (8.1.0 (81) Build).
      Workflow is as follows:
      1. Edit in HD timeline (Apple ProRes 422 or Uncompressed 8-bit YUV)
      2. Choose Export -> Media
      3. Setup export settings. (Format doesn't really matter. The problem shows regardless.)
        • Format: MXF Op1a
        • Video Codec: IMX 30 PAL
        • Aspect D1/DV PAL Widescreen 16:9
        • Render at Maximum Depth
        • Set Start Timecode to Zero
        • Use Maximum Render Quality
      I always double check my results in ScopeBox as well as Premiere's internal meters. Everyting looks fine:
      When the export is finished I check it again with ScopeBox, and now the file looks like this:
      And it is rejected because of illegal broadcast values.
      Is anyone else seeing the same thing?
      Best,
      Peter
