1 Reply Latest reply on Dec 9, 2014 3:49 PM by Dave LaRonde
    no sound in ram preview
    odbyt
      Hi, there's no sound in my composition after importing my .mts file into it. The waveform is empty.
      Audio is fine when I convert the file to h264, but I do not want to end up converting my every footage.
      Any ideas what can I do?
      file info:
      General
      Format                                   : BDAV
      Format/Info                              : Blu-ray Video
      File size                                : 45.5 MiB
      Duration                                 : 13s 579ms
      Overall bit rate mode                    : Variable
      Overall bit rate                         : 28.1 Mbps
      Maximum Overall bit rate                 : 28.0 Mbps
      Video
      Menu ID                                  : 1 (0x1)
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : High@L4.2
      Format settings, CABAC                   : Yes
      Format settings, ReFrames                : 2 frames
      Codec ID                                 : 27
      Duration                                 : 13s 460ms
      Bit rate mode                            : Variable
      Bit rate                                 : 26.8 Mbps
      Maximum bit rate                         : 26.5 Mbps
      Width                                    : 1 920 pixels
      Height                                   : 1 080 pixels
      Display aspect ratio                     : 16:9
      Frame rate                               : 50.000 fps
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.258
      Stream size                              : 42.9 MiB (94%)
      Audio
      Menu ID                                  : 1 (0x1)
      Format                                   : AC-3
      Format/Info                              : Audio Coding 3
      Mode extension                           : CM (complete main)
      Format settings, Endianness              : Big
      Codec ID                                 : 129
      Duration                                 : 13s 472ms
      Bit rate mode                            : Constant
      Bit rate                                 : 192 Kbps
      Channel(s)                               : 2 channels
      Channel positions                        : Front: L R
      Sampling rate                            : 48.0 KHz
      Bit depth                                : 16 bits
      Compression mode                         : Lossy
      Stream size                              : 316 KiB (1%)
        • 1. Re: no sound in ram preview
          Dave LaRonde Level 6
          Sorry, but you're stuck transcoding all your footage.  The reason: your audio is embedded in the video track, and AE needs files with separate audio tracks.
          Or you could export audio-only, and sync up the track with the video in AE; it could be faster that way.
