2 Replies Latest reply on Dec 10, 2014 9:27 AM by JohnEvansIBM
    character style for font color only changes font size also
    JohnEvansIBM
      I created a character style to set the color for some text, color only.  When I apply it to a set of characters, it also changed the font face and size from 36 to 12.  Paragraph styles have the same problem.  If you want it to be 36 points, applying it changes to about half the desired size.  This has been a bug in CS6 (v13 & 13.0.6) and now in current version 20141014.r.257 on Mac 64bit both 10.9 and 10.10.
        • 1. Re: character style for font color only changes font size also
          Giordano - ACP Italy Adobe Community Professional
          From the Window menu open the panel styles> character styles after that click in the panel on the icon below foer a new character style > Double-click to open the properties and give the name to the style > in the properties panel define color, size and everything else.
          done this select the part of the text that should have those features and click on the style that you just created.
          • 2. Re: character style for font color only changes font size also
            JohnEvansIBM Level 1
            Thanks Gaetano,   in your instructions, you set the font family and size.  I want my character style to work on any font family and size.  I've discovered that character styles only work as overrides on a paragraph style with no other overrides. Notice from my middle screenshot that I had not set any font information. When you apply a character style to a block of characters which have overrides, you get a plus on the character style.  Clicking on the first icon (arrow), removes all the overrides and applies the character style, thus causing the font family and size change noted in my 3rd screenshot back to the default.  Myrid Pro Regular 12pt appears to be the default font and therefore is the font you get when you remove all overrides in order to apply the character style.
            By creating several paragraph styles and removing all overrides in the text for each, I was able to apply the character style with just the color.
            In conclusion, character styles are working but can only be applied to block of text that has either the default text or a paragraph style and no overrides.
