0 Replies Latest reply on Dec 9, 2014 4:18 PM by jackfrombc
    PDF to Blurb - incompatible format for uploading
    jackfrombc Level 1
      Using LR 5.3 Book Module. I laid out two books and output them as PDF. Attempted to upload one PDF to Blurb site, but received an error message that PDF was incompatible format. What do I need to set in LR such that it creates a Blurb-compatible PDF? Seems to me that it should be automatic - after all, Blurb is the designated print facility.
      I chose to use the PDF method rather than the "direct upload to Blurb" method because I wanted to review the PDF before printing. A previous book (uploaded directly) contained an error that I did not discover until after it was printed. The rendering process is very slow, so I reasoned that using PDF would only require it to be done once. Apparently I was wrong because I've had to render it a second time for direct upload.
