1 Reply Latest reply on Dec 10, 2014 6:46 AM by SAFEHARBOR11
    Clip will play with 'media player classic' but will not convert to premiere friendly file types without losing picture
    hkee182
      Usually I use 'Pavtube' video converter to change my files directly from my Canon D70 dslr or GoPro to .mpg files to import to Premiere CS5.5 . Never had a problem.
      I recently got sent a load of GoPro (.mov) files via an external harddrive, I've then moved them on to my own hard drive and gone to open them. They would only play audio with windows media player, VLC and quicktime. So, someone suggested I downloaded Media Player Classic... hurrah that worked and I could see the footage as well as hear it.
      I've now gone to convert this footage to .mpg files to import to Premiere. They do that just fine but the clips go back to just playing audio and a blank white screen.
      I'm really not the best at this and learning as I go along. I simply don't know what to try next, help please?
      Thanks!
      Here's what media info says;
      Format                      : MPEG-4
      Format profile              : QuickTime
      Codec ID                    : qt
      File size                   : 1.02 GiB
      Duration                    : 1mn 23s
      Overall bit rate mode       : Variable
      Overall bit rate            : 105 Mbps
      Encoded date                : UTC 2013-08-14 13:07:09
      Tagged date                 : UTC 2013-08-14 13:08:32
      Writing library             : Apple QuickTime
      AMBA                        :
      Video
      Format                      : AIC
      Codec ID                    : icod
      Codec ID/Info               : Apple Intermediate Codec
      Duration                    : 1mn 23s
      Bit rate mode               : Variable
      Bit rate                    : 104 Mbps
      Width                       : 1 920 pixels
      Height                      : 1 080 pixels
      Display aspect ratio        : 16:9
      Frame rate mode             : Constant
      Frame rate                  : 25.000 fps
      Color space                 : YUV
      Chroma subsampling          : 4:2:0
      Bit depth                   : 8 bits
      Scan type                   : Progressive
      Bits/(Pixel*Frame)          : 1.999
      Stream size                 : 1.00 GiB (99%)
      Language                    : English
      Color primaries             : BT.709
      Transfer characteristics    : BT.709
      Matrix coefficients         : BT.709
      Audio
      Format                      : PCM
      Format settings, Endianness : Little
      Format settings, Sign       : Signed
      Codec ID                    : sowt
      Duration                    : 1mn 23s
      Bit rate mode               : Constant
      Bit rate                    : 1 536 Kbps
      Channel(s)                  : 2 channels
      Channel positions           : Front: L R
      Sampling rate               : 48.0 KHz
      Bit depth                   : 16 bits
      Stream size                 : 15.2 MiB (1%)
      Language                    : English
