1 Reply Latest reply on Dec 10, 2014 4:27 AM by Dirk Becker
    https://forums.adobe.com/message/6999731
    AdobeScripting Level 1
      Hello,
      why do we get the following exception, when a user closes "InDesign CC"?
      "The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)"
      When the mentioned exception occurs, then InDesign sadly won't start programmatically.
      Respectively, should we change the code in the method OpenIndesignAndPrint() ?
      static InDesign.Application application;
      InDesign.Document OpenIndesignAndPrint()
        if (application == null)
            // works fine. If InDesignCC isn't started, then it gets programmatically started
            application =  (InDesign.Application)this.COMCreateObject("InDesign.Application");
          else
            // A User has already started InDesign manually. So don't start InDesignCC a second time.
          InDesign.Document doc = (InDesign.Document) application.Open(sPath, true);
          // here code for printing programmatically
      Main()
        OpenIndesignAndPrint(); // works fine. InDesignCC will get programmatically started (if a user hasnÄt started it yet)
        OpenIndesignAndPrint(); // works fine. The code internally "knows" that InDesignCC is already started.
        // however, if a user closes "InDesign CC", then the following exception occurs when programmatically executing OpenIndesignAndPrint()
        // "The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)"
        // Why doesn't OpenIndesignAndPrint() open InDesignCC programmatically?
        • 1. Re: https://forums.adobe.com/message/6999731
          Dirk Becker Level 4
          Your COMCreateObject creates a local proxy object within your execution environment.
          When the matching remote object ceases to exist, you have to create a new local proxy and that way relaunch the remote process.
          When you catch that error you should
          - decode the multiple possible causes such as RPC_E_SERVER_DIED
          - create a new object when appropriate (not when the object is on a remote machine and your network is down, cable is removed, the user has uninstalled InDesign ;-) and so forth)
          - retry the command
          - eventually use a loop and give up with a warning after n attempts
