3 Replies Latest reply on Dec 10, 2014 4:08 AM by Max_OsbyParca
    Problem with putting shadow on text over another object
      See the attached file on the following link https://dl.dropboxusercontent.com/u/21034413/TEST_PROBLEM.indd.
      I try to give a outer glow effect on text that goes over a white rectangle; in the real case it's an image with a white background. As you can see, the shadow effect does not apply on the parts going over the rectangle. I can't find out which configuration it is that influences this.
      Thanks in advance and best wishes,
