• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Coldfusion 10 Update 15 broke our Coldfusion installation
New Here ,
Dec 10, 2014 Dec 10, 2014
Installation hung up here:
Failed to copy hotfix files:C:\Users\itsm-sse-svc-cf\331588.tmp\dist\cfusion
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Failed to copy the hotfix files to the target location:E:\ColdFusion10\cfusion
                                            FATAL ERROR - E:\ColdFusion10\cfusion\bin\coldfusion.exe (The process cannot access the file because it is being used by another process)
Tried several times, making sure all services were stopped, but no luck.
But uninstaller won't work either.
All coldfusion pages get this error:
Service Temporary Unavailable!
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
  Jakarta/ISAPI/isapi_redirector/1.2.32 ()
If I try an html page on the server, though, it works.
I did recreate the connectors afterward.
I guess we will try and reinstall CF10 really, really frustrating.  Thankfully it was on our dev server, not live.  Will not install this update on live until it's fixed....
Views
595
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
No need to uninstall CF10 completely. It seems like, you don't have permissions on the hotfix directory mentioned in your post.
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
New Here ,
I had a similar problem with a CF11 update. I solved it by rebooting the server. That is an OS reboot not just restarting CF.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 11, 2014 Dec 11, 2014
(Restarting the service did not do it, btw.)  I was able to get update 15 uninstalled, but the service still doesn't work.  Strangely, I was able to uninstall 15 only after uninstalling 12 and then reinstalling 15.  However now I can't install 12 and get a similar error:
This seems to be the core issue.  However, it is not running and I can add and delete test files in that directory.  This makes me wonder if there is some sort of lock file which is not going away and making windows think codfusion.exe is in use...
All I can say, is thank goodness we tried this on dev first!
Votes
Translate
Translate
Report
Report
New Here ,
"(Restarting the service did not do it, btw)"
No it will not - You have to restart the box, a sever reboot.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 12, 2014 Dec 12, 2014
LATEST
We did a full reboot as well, no dice.  Currently awaiting call back from Adobe to work through it.
Votes
Translate
Translate
Report
Report
Resources
Documentation
