1 Reply Latest reply on Dec 10, 2014 10:04 PM by kenarli91
    JavaScript transfer indesign graphics from Illustrator
    kenarli91 Level 1
      hello;
      I want to write a code. The function of this code will be. I put avariable to each work in an Illustrator file. indesign javascript code with variables that make up the value entered in the dialog window, I want to help a command. Examples of thevariables that 5 of my illustrator file I think. I have written codeI would like the placement of 10 items found in the firstworksheet in the summer of 10 I 10 I want to be the firstvariable in the dialog box and illustrator file.
      The reason I want to use this code I'm stringing them one by one and really slow going. I succeed in writing this code you will earn a lot of time really
      I want to continue on this code
      var myDocument = app.activeDocument;
      myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS;
      myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
      var sekil = new Array;
      sekil = ["Kare", "Oval"]
      var myDialog = app.dialogs.add({name:"Sablon Olusturma", canCancel:true});
      with (myDialog){
          with (dialogColumns.add()){
              with (borderPanels.add()){
                  with(dialogColumns.add()){
                      staticTexts.add({staticLabel:"Kalip Eni :", minWidth:90});
                      staticTexts.add({staticLabel:"Kalip Boyu :", minWidth:90});
                      var kalipEn = textEditboxes.add();
                      var kalipBoy = textEditboxes.add();
              with(borderPanels.add()){
                      staticTexts.add({staticLabel:"Ara Bosluk :", minWidth:90});
                      var gutter = textEditboxes.add();
                      staticTexts.add({staticLabel:"Tekli Eni :", minWidth:90});
                      staticTexts.add({staticLabel:"Tekli Boyu :", minWidth:90});
                      var tekliEn = textEditboxes.add();
                      var tekliBoy = textEditboxes.add();
                      staticTexts.add({staticLabel:"Cizim Sekli :", minWidth:90});
                      staticTexts.add({staticLabel:"Radius :", minWidth:90});
                      var myDrop = dropdowns.add({stringList:sekil, selectedIndex:0});
                      var tRadius = textEditboxes.add();
      var diaSonuc = myDialog.show();
      if (diaSonuc == true){
          var kEn = parseInt(kalipEn.editContents);
          var kBoy = parseInt(kalipBoy.editContents);
          var kgutter = gutter.editContents;
          if ((kgutter == null) || (kgutter == "")){
              kgutter = 0;
          } else {
              kgutter = parseInt(kgutter);
          var tEn = parseInt(tekliEn.editContents);
          var tBoy = parseInt(tekliBoy.editContents);
          var myRadius = tRadius.editContents;
          if ((myRadius == null) || (myRadius == "")){
              myRadius = 0;
          } else {
              myRadius = parseInt(myRadius);
          var yatay = Math.floor(kEn / (tEn+kgutter));
          var dikey = Math.floor(kBoy / (tBoy+kgutter));
          var genislik = (tEn * yatay) + (kgutter * (yatay - 1));
          var boy = (tBoy * dikey) + (kgutter * (dikey - 1));
          var startMarginLeft = (kEn - genislik) / 2;
          var startMarginTop = kBoy - (boy+10);
          if (startMarginLeft < 7){
              yatay = yatay -1;
          if (startMarginTop<10){
              dikey= dikey-1;
          var sonuc = "Yatay :" + yatay + "  " + "Dikey :" + dikey + "\n Kaliptaki Etiket Sayisi :" + (yatay*dikey);
          alert(sonuc);
          var myLayer = myDocument.layers.item("Sablon");
          try{
              myLayerName = myLayer.name;
          catch (myError){
              var myLayer = myDocument.layers.add({name:"Sablon"});
          var myCutterColor = myDocument.colors.item("Bicak");
          try{
              myCutterColorName = myCutterColor.name;
          catch(myError){
              var myCutterColor = myDocument.colors.add({name:"Bicak", model:ColorModel.process, colorValue:[0, 100, 100, 0]});
          var myNoneSwatch = myDocument.swatches.item("None");
          var myRegistration = myDocument.colors.item("Registration");
          var myEtiket = new Array;
          var myCross1 = new Array;
          var myCross2 = new Array;
          var myCross3 = new Array;
          var myCross4 = new Array;
          var myCross5 = new Array;
          var myCross6 = new Array;
          var myCross7 = new Array;
          var myCross8 = new Array;
          if (myDrop.selectedIndex == 0){
              myEtiket[0] = myDocument.rectangles.add(myLayer, undefined, undefined, {strokeColor:myCutterColor, strokeWeight:0.25, fillColor:myNoneSwatch, geometricBounds:[startMarginTop, startMarginLeft, (tBoy+startMarginTop), (tEn+startMarginLeft)]});
              if (myRadius != 0){
                  myEtiket[0].cornerOption = CornerOptions.ROUNDED_CORNER;
                  myEtiket[0].cornerRadius =myRadius;
          if (myDrop.selectedIndex == 1){
              myEtiket[0] = myDocument.ovals.add(myLayer, undefined, undefined, {strokeColor:myCutterColor, strokeWeight:0.25, fillColor:myNoneSwatch, geometricBounds:[startMarginTop, startMarginLeft, (tBoy+startMarginTop), (tEn+startMarginLeft)]});
          myCross1[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[startMarginTop, (startMarginLeft-3), startMarginTop, (startMarginLeft-10)]});
          myCross2[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[(startMarginTop+tBoy), (startMarginLeft-3), (startMarginTop+tBoy), (startMarginLeft-10)]});
          myCross3[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[startMarginTop, (startMarginLeft+genislik+3), startMarginTop, (startMarginLeft+genislik+10)]});
          myCross4[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[(startMarginTop+tBoy), (startMarginLeft+genislik+3), (startMarginTop+tBoy), (startMarginLeft+genislik+10)]});
          myCross5[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[(startMarginTop-3), startMarginLeft, (startMarginTop-10), startMarginLeft]});
          myCross6[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[(startMarginTop-3), (startMarginLeft+tEn), (startMarginTop-10), (startMarginLeft+tEn)]});
          myCross7[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[(startMarginTop+boy+3), startMarginLeft, (startMarginTop+boy+10), startMarginLeft]});
          myCross8[0] = myDocument.graphicLines.add(myLayer,undefined, undefined,{strokeColor:myRegistration, strokeWeight:0.25, fillcolor:myNoneSwatch, geometricBounds:[(startMarginTop+boy+3), (startMarginLeft+tEn), (startMarginTop+boy+10), (startMarginLeft+tEn)]});
          var mmToPoint = 2.83464567
              for (var verti = 1; verti <= (dikey-1); verti++){
              var myVertDist = ((tBoy+kgutter)*verti)*mmToPoint;
              var myTransformationMatrix = app.transformationMatrices.add({verticalTranslation:myVertDist});
              myEtiket[verti] = myEtiket[0].duplicate();
              myCross1[verti] = myCross1[0].duplicate();
              myCross2[verti] = myCross2[0].duplicate();
              myCross3[verti] = myCross3[0].duplicate();
              myCross4[verti] = myCross4[0].duplicate();
              myEtiket[verti].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix);
              myCross1[verti].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix);
              myCross2[verti].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix);
              myCross3[verti].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix);
              myCross4[verti].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix);
          for(var diz = 0; diz <= (dikey-1); diz++){
              for (var myCounter = 1; myCounter <= (yatay-1); myCounter++){
                  var myDistance = ((tEn + kgutter)*myCounter)*mmToPoint;
                  var myTransformationMatrix1 = app.transformationMatrices.add({horizontalTranslation:myDistance});
                  myEtiket[dikey+myCounter] = myEtiket[diz].duplicate();
                  myEtiket[dikey+myCounter].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix1);
          for (var yanDiz = 1; yanDiz <= (yatay-1); yanDiz++){
              var myDistance = ((tEn + kgutter)*yanDiz)*mmToPoint;
              var myTransformationMatrix2 = app.transformationMatrices.add({horizontalTranslation:myDistance});
              myCross5[yatay+yanDiz] = myCross5[0].duplicate();
              myCross6[yatay+yanDiz] = myCross6[0].duplicate();
              myCross7[yatay+yanDiz] = myCross7[0].duplicate();
              myCross8[yatay+yanDiz] = myCross8[0].duplicate();
              myCross5[yatay+yanDiz].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix2);
              myCross6[yatay+yanDiz].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix2);
              myCross7[yatay+yanDiz].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix2);
              myCross8[yatay+yanDiz].transform(CoordinateSpaces.pasteboardCoordinates, [[0,0], BoundingBoxLimits.geometricPathBounds], myTransformationMatrix2);
          myDialog.destroy();
        • 1. Re: JavaScript transfer indesign graphics from Illustrator
          kenarli91 Level 1
          var myGraphicFile = File.openDialog("Choose a graphic file");
          if((myGraphicFile != "")&&(myGraphicFile != null)){
          var myGraphic = myDocument.pages.item(0).place(myGraphicFile);
          myGraphic = myGraphic[0];
          var myObjectStyle = myDocument.objectStyles.item("GraphicFrame");
          try {
          var myName = myObjectStyle.name;
          catch (myError){
          myObjectStyle = myDocument.objectStyles.add({name:"GraphicFrame"});
          myObjectStyle.enableStroke = true;
          myObjectStyle.strokeWeight = 3;
          myObjectStyle.strokeType = myDocument.strokeStyles.item("Solid");
          myObjectStyle.strokeColor = myDocument.colors.item("Red");
          var myFrame = myGraphic.parent;
          myFrame.applyObjectStyle(myObjectStyle, true);
          myFrame.geometricBounds = [0,0,144,144];
          myFrame.fit(FitOptions.proportionally);
          myFrame.fit(FitOptions.frameToContent);
          var myBounds = myFrame.geometricBounds;
          var myGraphicWidth = myBounds[3]-myBounds[1];
          var myTopMargin = myDocument.pages.item(0).marginPreferences.top;
          myFrame.move([myPageWidth-myGraphicWidth, myTopMargin]);
          myFrame.textWrapPreferences.textWrapMode = TextWrapModes.BOUNDING_BOX_TEXT_WRAP;
          myFrame.textWrapPreferences.textWrapOffset = [24, 12, 24, 12];
          can you help in this work illustrator file with the abovecodes in ads pages I want to have my knees I want to transferto the variable indesign program, but the code does not work?I'm using CS6. Thanks to everyone
