6 Replies Latest reply on Feb 10, 2015 6:37 AM by BobLevine
    Why are dots missing from PDF output?
    The Juggler
      When I use the 'line' tool with dots, (in this case to draw a line-break,) AND export a .pdf, it often leaves out a single dot in the line. There are no objects intersecting the line, or even within a half-inch of its location. The missing dot is consistent across the document, nearly always the second or third dot in the line. And this happens with all forms of dots - normal, japanese, etc. The dot is present in the InDesign application, just not in the material it outputs.
      Thanks a million for your help!
      Screenshots below:
