• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Cannot download adobe flashplayer
Guest
Dec 11, 2014 Dec 11, 2014
HI, I am unfortunately on the Australian NBN satellite broadband
This service is slow and getting slower beyond belief and after many, many attempts I could finally download install_flashplayer16x32_mssd_aaa_aih but when I try and run the installer it sticks at about 30% and rarely goes to %40
and then the connection drops EVERYTIME
I need to find where I can get and download a complete flash player install file so that I can finally put flash on my computer
I would appreciate anybodies help asap
Views
574
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Dec 17, 2014 Dec 17, 2014
Hi, I have exactly the same problem. NBN satellite etc.
I have just posted this before I saw your post so will include it below. I have not found a solution so I have to continue to use the older and vulnerable version in Firefox which requires me to enable it when requested.
Win XP. Firefox 34.0.5 (latest)
The Flash  Player download keeps failing with lost connection and then gives up.I am on a  satellite Internet connection.
It seems to be extremely slow even when loading the installer which is only 1MB. Then when I run the installer and it starts to download the installation there are frequent messages about losing the connection and then finally gives up.
I have had problems with other software failing when I am on a satellite link. This is most likely because of the huge latency which may be taken as a link failure. Ping times are typically 800ms but can be 2000ms sometimes!
Votes
Translate
Translate
Report
Report
Guest
I have just received this from Adobe. I hope it will help.
Hello,
The online shim installer, which you are using actually downloads and installs Flash Player silently in the background.  If your satelite connection is experiencing latency issues it could result in the failure to download.  Please try the full installer posted at the bottom of the Installation problems | Flash Player | Windows page, in the 'Still having problems' section.
Votes
Translate
Translate
Report
Report
Guest
It worked!
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
This is the full program and this worked for me
Adobe Flash Player Distribution (FULL)
http://www.adobe.com/products/flashplayer/distribution3.html
Votes
Translate
Translate
Report
Report
