1. Re: wrong trigger
resdesign Dec 11, 2014 8:02 AM (in response to marc huber)If you are using SVG files, you should use edge commons to work with them so that you can get to each parts as vectors.
2. Re: wrong trigger
resdesign Dec 11, 2014 8:04 AM (in response to marc huber)I forgot to mention: Otherwise the files act as png files where the transparent part is no truly transparent.
3. Re: wrong trigger
marc huber Dec 11, 2014 8:27 AM (in response to resdesign)Thanks for your fast response. Can you please be more specific? i installes edge commons but i dont know how this should help me.
4. Re: wrong trigger
resdesign Dec 11, 2014 8:45 AM (in response to marc huber)Hello,
If you use edge commons SVG plugin, you can access specific parts of the image. Here is a sample: Clouds
If you need an example let me know.
5. Re: wrong trigger
resdesign Dec 11, 2014 8:47 AM (in response to marc huber)Keep in mind that if you use EC then you will need to insert interactivity code in the AI files. Then you can use the EC code in Animate.
What version do you have?
6. Re: wrong trigger
marc huber Dec 11, 2014 11:05 PM (in response to resdesign)I dont use Edge Code because i cant really code anyway. Ive got the Creative Cloud in the newest version. As i found i can make also some javascript actions for SVGs right in the illustrator. ive got to try it, and also this SVG plugin you told me. Thanks
7. Re: wrong trigger
resdesign Dec 12, 2014 3:57 AM (in response to marc huber)I Did not mean edge code I meant the code for Edge common (EC). Let me know if you need a sample.
8. Re: wrong trigger
marc huber Dec 12, 2014 7:13 AM (in response to resdesign)oh i would love to see a sample how its done. im pritty confused right now
