4 Replies Latest reply on Dec 12, 2014 3:00 PM by Ottographix
    click event for specific timeline label?
    Ottographix Level 1
      Hello,
      I am creating an interactive map: San Diego Gaslamp Interactive Walking Map
      ...it is still in progress at the moment, so only a few things work.
      This question is in regards to the "LODGING/ACCOMMODATIONS" menu on the right hand side.
      I am trying to create 2 click events. Click to open and click to close, so I'm wondering if it's possible to do something like this:
      if at label 2 sym.stop("label1");
      if at label 1 sym.stop("label2");
      I'm not sure how to code the "if at label 2" part...or if it's even possible.
      Any help would be greatly appreciated!
        • 1. Re: click event for specific timeline label?
          resdesign Adobe Community Professional & MVP
          Try:
          var MyStop=0;
          sym.$('btn').bind("click",function(){if (MyStop==0){
          sym.stop("label1");
          MyStop=1;
          } else {
          sym.stop("label2");
          MyStop=0;
          On Thu, Dec 11, 2014 at 2:28 PM, Ottographix <forums_noreply@adobe.com>
          • 2. Re: click event for specific timeline label?
            Ottographix Level 1
            Hi Redesign,
            Thanks for the response!
            I adjusted your code to my document and added the following to the "lodgingindexbutton", but it doesn't appear to be working:
            var MyStop=0;
            sym.$('lodgingindexbutton').bind("click",function(){if (MyStop==0){
            sym.stop("lodgingstart");
            MyStop=1;
            } else {
            sym.stop("lodgingover");
            MyStop=0;
            Not sure if I did something wrong?...
            If you are up for it, I have attached the original files here:
            http://adobe.ly/1vZTtqf
            I am trying to add the "2 clicks" code to the "lodgingindexbutton".
            You can get to it by double-clicking the Index in the upper right corner.
            Then you will see the "lodgingindexbutton" at the top of the index.
            As you can see, I currently have it set to just open, then you can close it by clicking the triangle.
            This is working and will be fine, but I thought it would be nice to click open and click closed as it seems that what a user would want to do.
            Any help would be appreciated. Thanks so much!!
            Jason
            • 3. Re: click event for specific timeline label?
              Something is missing, Please add this to compositionReady:
              var MyStop=0;
                if (MyStop==0){
                MyStop=1;
                } else {
                MyStop=0;
              • 4. Re: click event for specific timeline label?
                Ottographix Level 1
                hmm...still no worky.
                I copied and pasted the code from your post directly into compositionReady and previewed it locally.
                Not sure if I'm doing something wrong?
                I really appreciate your help...but please don't kill yourself trying to figure this out!
                I found a work-around that will suffice.
                Thanks redesign!
