5 Replies Latest reply on Dec 17, 2014 9:26 AM by AS Scripter
    AS how to call place-dialog with predefined path?
    DBLjan Level 3
      Hi there,
      im frequently using 3 paths to get pictures and logos to place, so I asked a while ago how to script that, and got this answer:
      #target Indesign
      try{
      var pathToPredefinedFolder = Folder('/Volumes/Server1/Folder1/');//Folderobject
      app.place(pathToPredefinedFolder.openDlg ('Get some files', '', true)) //prompt, filter, multiselect
      }catch (e){}
      Problem is, im not familiar with JS, and cant modify to my needs. I managed to change the path thou. But:
      I need a little help how to get this done by AppleScript.
      Thanks ahead,
      Jan
        • 1. Re: AS how to call place-dialog with predefined path?
          AS Scripter Level 1
          set sourceFolder1 to "HD:images1:"
          set sourceFolder2 to "HD:images2:"
          set sourceFolder3 to "HD:images3:"
          tell application "Adobe InDesign CS6"
            tell document 1
            tell page 1
            set filePathToPlace1 to (sourceFolder1 & "1.tif") as string
            tell rectangle 1
            place file filePathToPlace1
            end tell
            set filePathToPlace2 to (sourceFolder2 & "2.tif") as string
            tell rectangle 2
            place file filePathToPlace2
            end tell
            set filePathToPlace3 to (sourceFolder3 & "3.tif") as string
            tell rectangle 3
            place file filePathToPlace3
            end tell
            end tell
            end tell
          end tell
          • 2. Re: AS how to call place-dialog with predefined path?
            DBLjan Level 3
            Thank you, but i need that place-dialog. Guess i'm gonna have to invoke the menu.
            I thought there must be a function for this, since JS does simple things like .place .openDlg
            • 3. Re: AS how to call place-dialog with predefined path?
              AS Scripter Level 1
              -- one rectangle is selected
                activate
                tell document 1
                set theRect to object reference of selection
                end tell
              end tell
              tell application "Finder"
                activate
                set fp to (choose file) as string -- "fp" = full path of file
              end tell
                activate
                tell theRect
                place file fp
                end tell
              end tell
              • 4. Re: AS how to call place-dialog with predefined path?
                DBLjan Level 3
                Meh. I thank you for your commitment, but it too limited, having to have a box selected, not beeing to multiselect files to place, also cant access optional import-options…
                Or maybe someone can enhance the JavaScript to following intent:
                I want to save time, because I always press command+f to get into the search.
                My idea was, to add something like …
                tell application "System Events"
                        activate application "Adobe InDesign CS5.5"
                        keystroke "f" using {command down}
                end tell
                but I cant do this in JS…maybe someone can help?
                • 5. Re: AS how to call place-dialog with predefined path?
                  AS Scripter Level 1
                  set fd to (alias "HD:images:HiRes:") -- default folder of following choose file dialog
                  set fp to (choose file with prompt "Select some files" default location fd with multiple selections allowed) -- returns a list of aliases
