14 Replies Latest reply on Dec 16, 2014 5:21 PM by A.T. Romano
    Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
    Main Menu
      I have inserted a picture inside the frame on the main menu template. It fitted perfect, even when I did a preview. But after burning the DVD the picture had shifted.
      I also changed the title text underneath the picture. Looked good but again after burning, The font, font size, and layout had changed. It even had added some letters and symbols in the middle of the text. Any suggestions?
        • 1. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
          A.T. Romano Level 7
          main menu
          What version of Premiere Elements are you using and on what computer operating system is it running? Is the setup NTSC or PAL?
          What did you (manually) or the project (automatically) set as the project preset for this project in order to match the properties
          of your source media? If you do not know, please tell us the Edit Menu/Project Settings/General readings that you see for Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio (even if grayed out).
          What did you select for the burn to disc...if Premiere Elements 11, 12, or 13 in NTSC setup
          Publish+Share
          Disc
          DVD disc
          with preset = NTSC_Dolby Digital? or with preset = NTSC_Widescreen_Dolby DVD?
          Which specific disc menu theme did you select, and did its thumbnail in display area have "HD" in the upper right corner of
          the thumbnail?
          Let us start here and then plan the appropriate troubleshooting strategy.
          Thank you.
          ATR
          • 2. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
            Main Menu Level 1
            Thank you for your quick response. Sorry I didn't include all the details
            to answer my question.
            Here are the answers.
            I'm using, as of recent, version 13 of Premier Elements and running this on
            Windows 7, Setting: NTSC.
            I used the following default settings:
            Editing mode: HD1080i
            Time base: 29.97 frames/second
            Frame size: 1920H-1080V
            PAR: Square pixels (1.0)
            Fields: Upper field first
            Display format: 30 fps  Drop frame timecode
            Title safe area: 20% H-20% V
            Action Safe area: 10% H-10% V
            To burn DVD I used Adobe's Public+Share settings: DVD - Preset:
            NTSC-Widescreen_Dolby DVD
            As theme I used: art in motion with HD symbol.
            All else creating my video worked well except this Movie Menu issue messes
            me up all the time.
            I hope this will give you enough information to help me get rid of this
            problem once and for all.
            Best wishes,
            Herman Maas☺
            [personal information removed... Mod - https://forums.adobe.com/docs/DOC-3731]
            [This is an open forum, not Adobe support, please do not post personal information]
            [If you are posting using email, please turn your 'sig file' function OFF for posting]
            • 3. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
              A.T. Romano Level 7
              Herman Maas
              Thanks for all the helpful information.
              Just, what are the properties of what you are putting on the Timeline 1920 x 1080p30, 1280 x 720p30, NTSC DV Widescreen, or something else?
              When you were in the Edit area with this project, were there any black borders around your video in the monitor or was the monitor space filled
              with the video?
              Thanks.
              ATR
              • 4. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                Main Menu Level 1
                Perhaps here is where my problem lies?
                My video is made up of 17 video clips, downloaded from the internet. These
                are various clips of short music concerts. Most of them have a frame size
                of 640 H x 360 V. But there are several with variable frame sizes. And yes,
                there are several with a black border all around or on both sides only and
                there are several that fill the screen. Most of the clips have a frame rate
                of 25 except one with 29 and another one with 23. Bit rate and data rate
                vary all over the place.
                All the clips are .mp4.
                Hope this helps,
                Herman Maas☺
                • 5. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                  A.T. Romano Level 7
                  Herman Maas
                  Could you invest a DVD disc in the following mini test
                  Using this same project, when you get to Movie Menu customization, do not do anything. Leave the default text and do not insert
                  any picture. Click Done in Movie Menu customization and move on to Publish+Share/Disc/DVD disc with preset = NTSC_Widescreen_Dolby DVD.
                  Do you see the same irregularities in the main menu when you play back the DVD-VIDEO on DVD disc on your DVD player?
                  The non customized main menu should look like
                  If that looks OK, then we go back to explore your step by step in Movie Menu customization. If that does not look OK,
                  then we will probably explore deleting the Adobe Premiere Elements Prefs file and then maybe uninstall, free ccleaner
                  run through, and then reinstall with antivirus and firewall(s) disabled.
                  We will be watching for the results of this mini test when you get the chance.
                  Thank you.
                  ATR
                  Add On...If you have a screenshot of the after burn to disc messed up menu, please post it in jpg format using
                  the Insert Image (camera icon) of the Reply.
                  • 6. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                    Main Menu Level 1
                    Hello ATR.
                    I have not been available for the weekend to write you back but it gave me
                    some time to think. To think about, why can't I see the irregularities
                    before I burn a DVD?
                    When I came back to the project I started again from scratch by inserting
                    the picture and the same text. Saved the project and closed Adobe Premier.
                    Then I opened it again, with the result that everything had changed as I
                    described before. Not that I'm cheap, by wasting a disk but I saved myself
                    a lot of time.
                    I have attached a before and after picture.
                    My photo is a 16:9 format. This I changed to a square format because the
                    frame in the movie menu is just about square. This solved the problem of
                    the picture wanting to shift.
                    The text, however, is still having the problem. It seems it doesn't like
                    double lines. I know it is meant to just have a small movie title but I
                    wrote a comment underneath the picture that required 2 lines because the
                    picture itself already had the title included.
                    So, in a way I answered my own questions but if you feel I'm going the
                    wrong way about it, please let me know.
                    While we're at it, is there a way to adjust the volume of the music that is
                    inserted in the movie menu?
                    Best regards,
                    Herman Maas☺
                    • 7. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                      A.T. Romano Level 7
                      Main Menu
                      Let me start with your latest question
                      There is no way to adjust the volume of audio that you insert into the disc menus while you are in the disc menu customization area of the program. But, there is a way to adjust that audio as follows
                      1. Import the original audio from the hard drive save location into a Premiere Elements project.
                      2. Adjust the volume* of the audio import on Expert workspace Timeline Audio Track 1.
                      3. Export the Timeline with its audio content (volume adjusted) using Publish+Share/Compute/Audio
                      with the preset for MP3 High Quality or Windows Waveform.
                      4. Then insert that MP3 or WAV into the disc menu** from the computer hard drive save location for the audio file.
                      *For Timeline audio volume adjust...highlight video clip, go to Adjust Tab/Adjustments Palette/Volume Panel expanded.
                      **Audio insert is max 30 seconds looping. No changing that. But, in disc menu customization, can change the start point for the audio insert.
                      Other question/reply in next post.
                      ATR
                      • 8. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                        A.T. Romano Level 7
                        Main Menu
                        Now with regard to the shifting picture insert and main menu text for the title.
                        I have looked at this in mini test runs. I cannot confirm a problem whether my insert was 16:9 or 4:3
                        for the space reserved for the video or still background insert in Art In Motion HD. So, I am not sure why your square picture instead
                        of 16:9 was the answer to the shifting picture insert. But, it worked for you. So, we will enjoy the success. But the
                        whys remain for me. If you wanted to invest more time in this, we could goes deeper into this. But it might be advisable
                        to see if these issues re-present in your next project.
                        As for the text, I cannot confirm a problem with one or two lines of text for the main menu title.
                        Could you post a screenshot of what these irregularities are looking like?
                        With the text concerns (2 lines), how many words are there in each line of text? Are you working with the
                        Safety Margins on in the disc menu customization area?
                        ATR
                        • 9. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                          Main Menu Level 1
                          I don't know why you didn't get the 2nd picture. I sent the before and
                          after.
                          Here is the after or irregular picture.
                          Herman Maas☺
                          • 10. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                            A.T. Romano Level 7
                            Herman Maas
                            Thanks for the reply. So far none of the screenshots have gotten posted.
                            Are you sending your replies by email notification or cell phone? If so, you might try using your computer browser to sign into the Adobe
                            Premiere Elements Forum and post your screenshots (as jpg) with the Reply's Insert Image icon (camera looking).
                            Thanks.
                            ATR
                            • 11. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                              Main Menu Level 1
                              Here is another try to insert the images. The left one is what I would like to see and the right one is what I get.  Herman.
                              • 12. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                                A.T. Romano Level 7
                                Herman Maas
                                Great screenshots.
                                I will do some experimenting to see if I can produce what appears to be a zoomed in and stretched look before after.
                                If you play back the DVD-VIDEO on DVD disc that has this menu problem and hit the Play Movie button, is the video changed
                                as well?
                                Just to confirm my understanding of your background information
                                Premiere Elements 13
                                Windows 7 64 bit
                                Project Preset = NTSC AVCHD Full HD1080i30
                                Burn to DVD disc = NTSC_Widescreen_Dolby DVD
                                Movie Menu = Art In Motion (display area thumbnail has HD in upper right corner).
                                If you have not done so already, please delete the Adobe Premiere Elements Pref file found
                                Local Disk C
                                Users
                                Owner
                                AppData
                                Roaming
                                Adobe
                                Premiere Elements
                                13.0
                                and in the 13.0 Folder is the Adobe Premiere Elements Prefs file that you delete. If that does not work, then delete the whole
                                13.0 Folder in which the Adobe Premiere Elements Prefs file exists. Be sure to be working with Folder Option Show Hidden Files,
                                Folders, and Drives active so that you can see the complete path cited.
                                We will be watching for your results.
                                Thanks you for the follow ups. Appreciated.
                                ATR
                                • 13. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                                  Main Menu Level 1
                                  Hi A.T.
                                  The answer to your first question: The main video has not been affected.
                                  All the background data you listed, is correct.
                                  I deleted the Adobe Premier Elements Pref file. I started a new project
                                  with only one of the video clips I had downloaded, took the original movie
                                  menu steps (including the double line text) and burned a DVD and.... to my
                                  delight, no discrepancies.
                                  I think we can close it off now. With this whole exercise corresponding
                                  back and forth and your excellent guidance, I'm happy now.
                                  I'm going to burn one more disk, this time with 2 different formatted video
                                  clips. Just to make sure. If it goes wrong, I might be back.
                                  In the mean time I'd like to wish you a wonderful Christmas and a
                                  prosperous 2015.
                                  Herman
                                  Herman Maas☺
                                  Tel: (613) 475-0866
                                  Cell: (613) 920-0886
                                  hamfgb <hamfgb@gmail.com>gmail.com <hamfgb@gmail.com>
                                  Get a signature like this.
                                  <http://r1.wisestamp.com/r/landing?promo=19&dest=http%3A%2F%2Fwww.wisestamp.com%2Femail-ins tall%3Futm_source%3Dextension%26utm_medium%3Demail%26utm_campaign%3Dpromo_19>
                                  CLICK
                                  HERE.
                                  On Tue, Dec 16, 2014 at 10:52 AM, A.T. Romano <forums_noreply@adobe.com>
                                  • 14. Re: Picture moves and text changes in the template of the movie menu after burning a DVD. How can I prevent this?
                                    A.T. Romano Level 7
                                    Herman Maas
                                    That for the updates and additional information on your Premiere Elements issues.
                                    Best of all, I am very glad to learn of your successes. Great job.
                                    Best wishes for the Holiday, New Year, and always
                                    ATR
