7 Replies Latest reply on May 11, 2006 12:12 AM by vinsoft58
    8.02 updater... is it really need?
    Level 7
      Is there any reason to update my DW8? It's running fine and now I see
      people are having issues with the updater.
      kim
      http://geekministry.com
        • 1. Re: 8.02 updater... is it really need?
          Level 7
          They finally address SQL security issues. If you use their built-in code for
          databases then you should update. If you role your own, then no need.
          "Kim" <not@this.com> wrote in message
          news:e3thr8$l76$1@forums.macromedia.com...
          > kim
          • 2. Re: 8.02 updater... is it really need?
            Level 7
            Excellent. Thanks
            >> kim
            kim
            • 3. Re: 8.02 updater... is it really need?
              vinsoft58
              I have problems with the new patch no.2.
              The program stops while updating and now the program doesn't wotk....
              • 4. Re: 8.02 updater... is it really need?
                Level 7
                Can you elaborate on the problem? Did the DW 8.0.2 updater installer
                hang while you were trying to install it? Did you get any type of
                error message? Maybe there was a dialog box hidden behind another
                dialog box?
                What exactly happens now when you try to open DW 8? Does it not
                launch? Do you get an error message?
                Try uninstalling and reinstallling DW. To uninstall DW 8 completely,
                please follow the steps in this TechNote, as there are some tricks to
                removing all of the settings:
                Uninstalling Studio 8 applications on Windows
                http://www.adobe.com/go/4e7826b7
                David Alcala
                Adobe Technical Support
                On Wed, 10 May 2006 21:25:37 +0000 (UTC), "vinsoft58"
                • 5. Re: 8.02 updater... is it really need?
                  Level 7
                  On Wed, 10 May 2006 18:07:33 -0700, David Alcala - Adobe
                  >dialog box?
                  When I ran the updater, it almost appeared to hang. It just took a
                  *very* long time to run, with no indication that anything was happening.
                  With enough patience, it did install. You just have to wait it out. ;-)
                  Gary
                  • 6. Re: 8.02 updater... is it really need?
                    Level 7
                    It was suggested in another group to uninstall all extensions before doing
                    the the update. I did that and I didn't have a problem. Of course, it may
                    just have been coincidence.
                    Susan
                    > kim
                    • 7. Re: 8.02 updater... is it really need?
                      vinsoft58 Level 1
                      I have installed on my pc the 8.1 version.
                      I have downloaded the patch 2.
                      I have closed all applications.
                      I run the patch and after some minutes it ask me the original cd.
                      Then it crash...
                      I have reinstalled the patch now and it seems work fine, but when I open dreamweaver I can see that is's always the 8.1 version!!!
                      It's incredible, i must disinstall and reinstall the programm to update!!!
