1 Reply Latest reply on Mar 29, 2015 6:34 PM by Tariq Dar
    Low quality on image/shadow
    calcalex
      Hello Adobe Community.
      I'm facing an issue with Acrobat, basically the quality of the image is low, you can clearly notice that by looking at the shadows.
      Here's an example:
      How the image looks on Microsoft Word:
      How it looks Acrobat:pdfimage.PNG
      You can clearly see that the Word image has better quality, it has no "lines" on the shadow part.
      I use the Menu Option "Acrobat"  to export the .doc into .pdf, sometimes I open the .doc with Acrobat to get the pdf.
      Thanks for the help
        • 1. Re: Low quality on image/shadow
          Tariq Dar Adobe Employee
          HI,
          Are you still facing this issue.
          let me know what is the version of Acrobat installed on your machine and what is the version of Ms word installed on your machine.
          If you are using Acrobat PDF maker to convert word document to PDF before you click on convert to PDF choose Preference button. A window will pop up named Acrobat PDFMaker.
          Choose high quality from the drop down and try to convert again, That should help you out.
          Regards,
          Ajlan.
