14 Replies Latest reply on Dec 14, 2014 10:08 AM by PilgrimsProcess
    Error message in extracting fixed layout ePub
    PilgrimsProcess
      I get the following message, which I don't understand at all:
      Index Page entry not found: 13
      What follows is the folder where the files are stored, then:
      CornwallEPUB.indd" is missing: 13
      Any idea about what this means?
        • 1. Re: Error message in extracting fixed layout ePub
          What OS?
          Which version of ID? Which dot version?
          What are you exporting? A single INDD file or a book file or a single file out from a book file?
          Give us all essential information, otherwise it will be rather guessing than helping.
          • 2. Re: Error message in extracting fixed layout ePub
            BobLevine MVP & Adobe Community Professional
            moved to InDesign epub forum.
            • 3. Re: Error message in extracting fixed layout ePub
              Steve Werner Adobe Community Professional & MVP
              Your title says, "Error message in extracting fixed layout EPUB". What do you mean by extracting?
              Is there this an error when exporting EPUB (Fixed)? Is an EPUB fixed layout created? What happens when you view it? What viewing app are you using?
              What version of InDesign (exactly) produced the error?
              • 4. Re: Error message in extracting fixed layout ePub
                PilgrimsProcess Level 1
                I'm running inDesign 2014 in Creative Cloud. The ePub fixed layout plays perfectly on my iPad, but when I run ePubCheck I get hundreds of errors.
                • 5. Re: Error message in extracting fixed layout ePub
                  I'm exporting a book of some 250 pages from my Mac IMac.
                  • 6. Re: Error message in extracting fixed layout ePub
                    What kind are these hundreds of errors? Is it always the same error or at least the same kind of error?
                    Can you give us some examples?
                    When you work with InDesign, do you work with styles? Do you use a lot of overrides? Did you specify the tag export section of paragraph, character and object styles?
                    Do you have several styles with the same export class but different settings?
                    Did you use scaling styles like glyph scaling, changed tracking, etc.?
                    Do you experience any export alerts in InDesign?
                    Can you specify what settings you used when you exported the file?
                    Is the export from a book or a single file?
                    • 7. Re: Error message in extracting fixed layout ePub
                      Here are some exmples:
                      nwallEPUB-140.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-140.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-141.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-141.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-142.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-142.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-143.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-143.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-144.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-144.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-145.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-145.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-146.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-146.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-147.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-147.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-148.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-148.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-149.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-149.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-150.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-150.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-151.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-151.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-152.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-152.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-153.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-153.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-154.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-154.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-155.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-155.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-156.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-156.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-157.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-157.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-158.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-158.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-159.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-159.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-160.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-160.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-161.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-161.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-162.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-162.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-163.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-163.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-164.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-164.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-165.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-165.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-166.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-166.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-167.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-167.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-168.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-168.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-169.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-169.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-170.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-170.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-171.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-171.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-172.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-172.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-173.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-173.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-174.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-174.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-175.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-175.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-176.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-176.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-177.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-177.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-178.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-178.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-179.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-179.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-180.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-180.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-181.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-181.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-182.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-182.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-183.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-183.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-184.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-184.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-185.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-185.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-186.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-186.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-187.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-187.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-188.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-188.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-189.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-189.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-190.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-190.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-191.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-191.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-192.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-192.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-193.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-193.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-194.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-194.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-195.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-195.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-196.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-196.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-197.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-197.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-198.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-198.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-199.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-199.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-200.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-200.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-201.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-201.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-202.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-202.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-203.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-203.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-204.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-204.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-205.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-205.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-206.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-206.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-207.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-207.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-208.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-208.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-209.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-209.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-210.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-210.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-211.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-211.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-212.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-212.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-213.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-213.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-214.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-214.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-215.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-215.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-216.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-216.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-217.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-217.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-218.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-218.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-219.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-219.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-220.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-220.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-221.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-221.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-222.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-222.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-223.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-223.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-224.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-224.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-225.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-225.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-226.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-226.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-227.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-227.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-228.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-228.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-229.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-229.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-230.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-230.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-231.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-231.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-232.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-232.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-233.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-233.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-234.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-234.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-235.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-235.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-236.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-236.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-237.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-237.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-238.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-238.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-239.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-239.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-240.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-240.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-241.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-241.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-242.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-242.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-243.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-243.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-244.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-244.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-244.xhtml(19): attribute "epub:type" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-244.xhtml(24): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-244.xhtml(50): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-245.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-245.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-245.xhtml(19): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-245.xhtml(57): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-246.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-246.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-246.xhtml(19): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-246.xhtml(50): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-247.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-247.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-247.xhtml(19): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-247.xhtml(54): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-248.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-248.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-248.xhtml(19): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-248.xhtml(54): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-249.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-249.xhtml(10): attribute "lang" not allowed here; expected attribute "class", "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-249.xhtml(19): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-249.xhtml(54): attribute "epub:type" not allowed here; expected attribute "dir", "style", "title" or "xml:lang"
                      ERROR: /OEBPS/CornwallEPUB-250.xhtml(5): attribute "charset" not allowed here; expected attribute "content", "dir", "http-equiv", "name", "scheme" or "xml:lang"
                      ERROR: /OEBPS/toc.xhtml(7): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(8): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(260): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(262): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(263): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(515): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(517): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(518): element "nav" not allowed anywhere; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/toc.xhtml(520): attribute "epub:type" not allowed here; expected attribute "accesskey", "charset", "class", "coords", "dir", "href", "hreflang", "id", "rel", "rev", "shape", "style", "tabindex", "target", "title", "type" or "xml:lang"
                      ERROR: /OEBPS/toc.xhtml(521): attribute "epub:type" not allowed here; expected attribute "accesskey", "charset", "class", "coords", "dir", "href", "hreflang", "id", "rel", "rev", "shape", "style", "tabindex", "target", "title", "type" or "xml:lang"
                      ERROR: /OEBPS/toc.xhtml(522): attribute "epub:type" not allowed here; expected attribute "accesskey", "charset", "class", "coords", "dir", "href", "hreflang", "id", "rel", "rev", "shape", "style", "tabindex", "target", "title", "type" or "xml:lang"
                      ERROR: /OEBPS/toc.xhtml(523): attribute "epub:type" not allowed here; expected attribute "accesskey", "charset", "class", "coords", "dir", "href", "hreflang", "id", "rel", "rev", "shape", "style", "tabindex", "target", "title", "type" or "xml:lang"
                      ERROR: /OEBPS/toc.xhtml(525): element "body" incomplete; expected element "address", "blockquote", "del", "div", "dl", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "ins", "noscript", "ns:svg", "ol", "p", "pre", "script", "table" or "ul" (with xmlns:ns="http://www.w3.org/2000/svg")
                      ERROR: /OEBPS/CornwallEPUB-49.xhtml(19): 'OEBPS/www.museumofwitchcraft.com': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-54.xhtml(20): 'OEBPS/www.st-nectansglen.co.uk': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-54.xhtml(20): 'OEBPS/www.facebook.com/stnectansglen': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-66.xhtml(22): 'OEBPS/www.arthur-online.co.uk': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-73.xhtml(23): 'OEBPS/www.peaceland.org.uk': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-121.xhtml(20): 'OEBPS/www.smallpilgrimplaces.org': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-126.xhtml(20): 'OEBPS/www.pengersickcastle.com': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-223.xhtml(28): 'OEBPS/Facebook.com/ScillyWalks': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-224.xhtml(20): 'OEBPS/www.islesofscilly-travel.co.uk': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-225.xhtml(20): 'OEBPS/www.friendly-guides.com': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-241.xhtml(28): 'OEBPS/www.meynmamvro.co.uk': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-242.xhtml(21): 'OEBPS/www.cornishancientsites.com': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-242.xhtml(25): 'OEBPS/www.meynmamvro.co.uk': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-243.xhtml(18): 'OEBPS/www.friendly-guides.com': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-243.xhtml(19): 'OEBPS/www.yellowpublications.co.uk': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-243.xhtml(26): 'OEBPS/www.smallpilgrimplaces.org': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-244.xhtml(82): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-245.xhtml(32): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-245.xhtml(42): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-246.xhtml(59): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-247.xhtml(25): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-247.xhtml(27): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-247.xhtml(77): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-248.xhtml(22): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-248.xhtml(27): 'OEBPS/': referenced resource missing in the package
                      ERROR: /OEBPS/CornwallEPUB-248.xhtml(83): 'OEBPS/': referenced resource missing in the package
                      END OF FILE ERRORS
                      • 8. Re: Error message in extracting fixed layout ePub
                        Yes I always work with styles and character styles. I chose the fixed layout option in iD 2014.
                        • 9. Re: Error message in extracting fixed layout ePub
                          AnneMarie Concepcion Adobe Community Professional
                          Willi: If he's exporting to EPUB (Fixed Layout) then the use of styles vs overrides doesn't matter, nor style mapping. All overrides are supported. All style mapping is ignored.
                          Pilgrims, it sounds like there's a problem with the file's index. You might want to delete the current index in the INDD file and regenerate it, then re-export to EPUB.
                          Also if you're using the Book feature — you're exporting to EPUB from the Book panel containing your collection of INDD files and not from the File menu of an individual INDD file — be sure all your INDD files are up to date and that you've turned on the checkmark for "Book" in the index panel before regenerating it.
                          AM
                          • 11. Re: Error message in extracting fixed layout ePub
                            It's possible that part of the problem is that you're using an out of date epub checker, one that checks only for epub 2, but you've got an epub 3 there.
                            Try again with one of these:
                            pagina GmbH Publikationstechnologien: EPUB-Checker
                            (Mac/Windows, scroll down the page to find the english text and download links)
                            EPUB Check 3.01 (Mac only)
                            First post in this thread: epubcheck for Mac OS X - MobileRead Forums
                            AM
                            • 12. Re: Error message in extracting fixed layout ePub
                              @ AnneMarie Concepcion:
                              The information that it was a fixed layout came later after my questions.
                              But I had also some problems with fixed layout when letters where scaled or when I use another tracking or when I used Caps as style. But not with the latest build, I haven't tested it yet as I don't have an EPUB project now open.
                              • 13. Re: Error message in extracting fixed layout ePub
                                Thanks much. I'll give that one a try.
                                • 14. Re: Error message in extracting fixed layout ePub
                                  Thanks, AnneMarie, the regenerated index and an up-to-date checker brought the problems within a range of being solved. When the list goes on for hundreds of items it becomes overwhelming! Thanks, everyone for your responses.
