3 Replies Latest reply on Dec 17, 2014 10:30 AM by A.T. Romano
    Nur den Audio-Teil eines Video-Clips noch einmal verwenden
    Gerhard Becker
      Möchte den Audio-Teil eines Video-Clips noch einmal verwenden und diesem Audio-Teil dann ein Standbild zufügen. Wer kann mir hier helfen?
        • 1. Re: Nur den Audio-Teil eines Video-Clips noch einmal verwenden
          A.T. Romano Level 7
          Gerhard Becker
          What version of Premiere Elements are you using and on what computer operating system is it running?
          In the absence of that information, I will generalize.
          1. You right click a copy of the Timeline file with the video and audio linked and then select Delete Video from the pop up.
          2. Then you drag your Still Image to the Timeline and align it with your audio file.
          You can leave that still audio positioning as is or "Group" the two so that they move together (if you want to move them together).
          For that, select/highlight the still and audio portions (hold down Shift and click video portion and then audio portion), right click in the selection, and select Clip Menu/Group from the pop up.
          Please let us know if that generalized answer works for you. If not, more details please.
          ATR
          • 2. Re: Nur den Audio-Teil eines Video-Clips noch einmal verwenden
            Gerhard Becker Level 1
            Hallo ATR,
            vielen Dank für Ihre Antwort.
            Auch wenn sie nur allgemein gehalten war, hat sie mir doch bei meinem Problem geholfen. Hat dann alles wunderbar funktioniert.
            Herzliche Grüße
            GerHil
            • 3. Re: Nur den Audio-Teil eines Video-Clips noch einmal verwenden
              A.T. Romano Level 7
              GerHil
              Great news of your success.
              Thank you for the follow up which is appreciated by all.
              Please do not hesitate to ask questions or to ask for clarification. We are glad for the opportunity
              to help you move forward in your Premiere Elements projects.
              Best wishes
              ATR
