13 Replies Latest reply on Dec 18, 2014 3:55 AM by aloooy_10
    Water trails ..
    aloooy_10
      Hi ,
      After exhausting every single bit i my brain , I didn't have any choice but to go to the forum and seek for the information.
      I've been experimenting with particular to create a water trails for the scene that I'm doing right now.
      So after pushing myself to the limits that what I've got :
      Could this be faked with out a 3d simulator ?
      I want to do it inside of after effects
        • 1. Re: Water trails ..
          Not sure what you are asking. The whole composition looks awful. An F-22 would never even fly so close above water, anyway. It's strictly a land-based fighter-interceptor aimed at high altitude, high speed chase.
          Mylenium
          • 2. Re: Water trails ..
            aloooy_10 Level 1
            I know it looks awful , thats why I have been asking for help.
            I was trying to do something like this to be clear :
            and thank you for your honesty about the comp .
            • 3. Re: Water trails ..
              You could use CC Particle World or (if you have purchased it from Red Giant's Trapcode Suite) use Particular to do that sort of thing.
              • 4. Re: Water trails ..
                aloooy_10 Level 1
                I'm using trapcode , but my problem is how can I blend it with water surface .
                I want to create a con vincible effects , Do you have any suggestions ??
                • 5. Re: Water trails ..
                  Andrew Yoole MVP & Adobe Community Professional
                  Real world water simulation is a very complex business.  You won't get brilliant results outside a true 3D application like C4D.  But as mentioned above, your best bet is to create plumes of particles with a Particle Generator effect like Particular.
                  How are you generating the water surface? Do you have the ability to manipulate the surface in any way?
                  • 6. Re: Water trails ..
                    bogiesan Level 4
                    I have no experience with Particular but CC Particle World is a 3D simulator. You can move the producer along a path with simple keyframes. The 3D interface for CCPW is supremely primitive and controlling the emitter while making it move is a challenge. Search for tutorials for PW, it's really a cool and difficult simulation system. You could also use Wave World to handle the wakes.
                    • 7. Re: Water trails ..
                      aloooy_10 Level 1
                      Yup I can manipulate the element 3d gives you a good performance with less rendering time.
                      • 8. Re: Water trails ..
                        aloooy_10 Level 1
                        I'm using particular by the way , I'm having some difficulties setting the parameters up .
                        Which Particular shape should I use ?
                        Sphere
                        Cloud
                        Sprite Texture
                        Any suggestion?
                        @AndrewYoole
                        • 9. Re: Water trails ..
                          bogiesan Level 4
                          You probably ought to hit the Particular forums at Red Giant. Is that who makes it?
                          • 10. Re: Water trails ..
                            aloooy_10 Level 1
                            Yes you're right
                            • 11. Re: Water trails ..
                              ThunderLion Level 1
                              Thats a tough simulation to pull off>  you could maybe do it with partilce world or particular  make it look like a fountain, then worr about the movement
                              • 12. Re: Water trails ..
                                You'll need a few layers pf particles to get a decent result.  Personally, I'd use spheres for my main particles, but I'd add another layer of larger, sparser sphere particles that move slower than the main ones, and another layer of cloudlet particles to create some mist-like spray, especially at the rear of the water plumes.  You probably want to overlay some foreground mist in the shot as well.
                                Also look at the colouring of the water in your reference pic compared to your own work.  The reference has great lighting and colour variation to enhance depth - only the very front of the spray is pure white.  You will need to light the particles or work with their colour and opacity to give them any sense of real depth.  At the moment your spray is pure white, so it has no sense of depth or of being in the same world as the ocean.
                                I haven't played much with Element 3D V2 yet, so I'm not totally across what it's fractal distortion tools can do, but if it's possible to create some surges on the water surface with a custom fractal map the whole thing will look a lot more real.
                                • 13. Re: Water trails ..
                                  aloooy_10 Level 1
                                  Thank you for the tips man , I will start tweeking the setting to get it right , and I hope that I do it right.
