11 Replies Latest reply on Dec 16, 2014 11:54 AM by EdGioja
    cfajax and jquery json - runs in browser but not scheduler
    EdGioja Level 1
      This one has me quite confused.
      I have a baby test routine:
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>Untitled Document</title>
          <script src="//ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script>
      <cfset dataout = timeformat(now(), "mm:ss")>
      <cfquery name="testrun" datasource="#application.ccidatasource#">
          update bridge
          set testtime = <cfqueryparam cfsqltype="cf_sql_varchar" value="#dataout#">
      $.getJSON("cciBridgeServices.cfc", {
                  method: 'testThis',
                  testtext: "schd",
                  returnformat: 'json',
                  queryformat: 'column'
              }, function(d){
                  var text = "";
                  var rows = d.ROWCOUNT;
      The service is simple as well
      <cffunction name="testThis" access="remote" returntype="numeric"
         description="Testing function used for pretty much anything" >
         <cfargument name="testtext" required="yes">
         <cflog application="yes" text="Hello auto run">
      update bridge
      set testcol = <cfqueryparam cfsqltype="cf_sql_varchar" value="#testtext#">
         <cfreturn 1>
      If I run testrun in a browser, everything is fine.
      If I create testrun as a scheduled task in the CF Administrator, or I use wget to process it, the testThis service doesn't run.
      I verified this by adding the <cflog..> command.  The mm:ss gets updated, but the text does not.it?
      I have tried adding a returnformat and an output="no" to the <cffunction>
      Can anyone explain what is happening here and how to fix it?
      Thank you in advance
