0 Replies Latest reply on Dec 16, 2014 5:31 AM by imoverhere
    How can i filter an xml object on an attribute?
    imoverhere
      I want address an xml object with .(@ attributeNameHere == "textToSearchForHere") and have it return the node it’s associated with.
      This is the text from the adobe help site and it’s similar to my actual code.  I’m querying this xml object: staticVar.employee.(@id=="347").  FlashBuilder 4.7 is returning an error “No such variable: @id”. when I look in debugger.
      This example is found in Adobe's help site: Adobe Flash Platform * Traversing XML structures
      The help site says
      The following expressions are all valid:
      • x.employee.(lastName == "McGee")—This is the secondemployeenode.
      • x.employee.(lastName == "McGee").firstName—This is thefirstNameproperty of the secondemployeenode.
      • x.employee.(lastName == "McGee").@id—This is the value of theidattribute of the secondemployeenode.
      • x.employee.(@id == 347)—The firstemployeenode.
      public var staticVar:XML =
      <employeeList>
            <employee id="347">
                 <lastName>Zmed</lastName>
                 <firstName>Sue</firstName>
                 <position>Data analyst</position>
            </employee>
            <employee id="348">
                 <lastName>McGee</lastName>
                 <firstName>Chuck</firstName>
                 <position>Jr. data analyst</position>
            </employee>
      </employeeList>;
      I’m expecting this: staticVar.employee.(@id=="347") will return the following node:
      <employee nu="347">
      </employee>
      If this is the wrong, then what is the correct way to access the xml node based on an attribute?  How can i get that node 347 in this example to be found and returned?  I've opened a ticket with the adobe help team and we're on the 8th day and they have not been helpful at all.
