• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Will installing Robohelp 6 trial screw up my Robohelp 5 installation?
Guest
Mar 14, 2007 Mar 14, 2007
I downloaded the Robohelp 6 trial for evaluation, but the installer 'strongly recommends' that I uninstall Robohelp 5 before continuing. I don't want to do this just to run a trial but if I don't will my it screw up Robohelp 5 anyway?
Thanks, Emma.
Views
371
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Check this link on what you can do and the potential pitfalls.
Votes
Translate
Translate
Report
Report
Engaged ,
Hi Emma,
Installing them side by side is fine. I've been running them on the same PC together for some time. Just be vigilent about opening project with the correct version! The best way to do this is only to open projects via the application (rather than windows explorer). You will notice that after the install all .xpj files are associated to Robohelp 6 - hence the above warning. These associations go back to Robohelp 5 when you uninstall 6.
BTW - It is not recommended by Adobe as the practice is not fully supported.
Hope this makes sense.
Kind Regards
Craig
Votes
Translate
Translate
Report
Report
Community Expert ,
I have had both running for some time without issue. One thing though you need to be very careful about. If you double click an XPJ file in Windows Explorer, it will open in RH6 and then you cannot open the project again in RH5. Well you can but that's another story and is not the best plan.
What you or your IT people need to do, is reassociate the XPJ file with RH5. You do that in Windows Explorer and it takes seconds. Then X5 projects will open in X5 and RH6 projects will try to but be blocked, you then open RH6 and point to the project or right click and use Open With. Both versions of RH will be there and it will be obvious which one to use.
Be aware the trial only handles a limited number of topics.
If in doubt, use a separate machine.
Votes
Translate
Translate
Report
Report
Guest
LATEST
Thanks for your quick responses guys - very helpful as always :o)
I will give it a go then.
Thanks again,
Emma.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
