• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Change "Show" Link Name
New Here ,
Mar 12, 2007 Mar 12, 2007
Hello. I am trying to change the "Show" link to "Display All Help" when viewing my compiled help project. I have gone into the project settings, advanced options and opened the LNG File tab. Under [Common], I have changed "Show=Show" to "Show=Display All Help," but it still says "Show" when the project is uploaded to my server and visitors launch the online help. I'm using RoboHelp 6 with FlashHelp set as the primary layout. I'd appreciate any help or ideas anyone might have. Thanks,
Ben
Views
632
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Welcome to the forum.
Sounds like the LNG file is not get through to the server. Check the properties on the server version and on the local version.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 13, 2007 Mar 13, 2007
Hello Peter. Thanks a lot for the help. I've looked through the project folder and a file called RoboEX32.LNG exists in the main folder, but there is no LNG file in the !SSL!/FlashHelp folder, which is what is uploaded to the server. Is there a setting somewhere I missed or something wrong with my layout generation that this file isn't being included? Thanks again.
Votes
Translate
Translate
Report
Report
Community Expert ,
Interesting. I got an email from RoboWizard with some information on this. This is what he said,
I don't believe the .LNG file is among the mix of output files. Seems there is an issue with the LNG file not working to influence a change in the output.
However, the fix seems easy enough. Inside the topic, where the code for the show link appears, a function named addShowButton() is called. A brief look at the .JS files seems to indicate the file named whtopic.js holds the function. Soooo, to set things the way the user wants to see, they will need to amend the whtopic.js file, locate the addShowButton
function and configure the text they wish to see. Once they do this, the topic should display as intended.
It's interesting because I did find the LNG file in my output! I didn't however test changing anything.
Hope that helps.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks again for the quick response. I found the .JS file and the addShowButton() function, which I changed manually. I'm unable to upload the project to the server for a little while, but I assume this will fix the problem. I just hope it doesn't change back every time I generate a new layout.
Thanks again.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 14, 2007 Aug 14, 2007
Sorry but the addshowbutton function does not show up in my whtopic.js file
Votes
Translate
Translate
Report
Report
New Here ,
Votes
Translate
Translate
Report
Report
Community Expert ,
Have you tried changing the title the correct way rather than this back door method that was to fix a particular problem?
Votes
Translate
Translate
Report
Report
Guest
"Have you tried changing the title the correct way rather than this back door method that was to fix a particular problem?"
Correct way is what I am seeking; I can find no other information of how to stop each topic from having the word SHOW appear above the topic title and my company is eager for a solution. Thanks in advance for your help if there's a way to fix this.
Votes
Translate
Translate
Report
Report
Community Expert ,
File | Project Settings | Advanced Button | LNG files and scroll down looking for Show.
Votes
Translate
Translate
Report
Report
New Here ,
YOU DA MAN DA MAN DA MAN!!!!!!!!
Votes
Translate
Translate
Report
Report
New Here ,
Now.... how the HECK can I get the help file to display the default to be the wwb_help.htm (frames page) instead of just the topic being displayed?? I mean, the customer clicks on the help button in a GUI, it calls the topic but doesn't show the topic INSIDE the frames page FIRST.
Votes
Translate
Translate
Report
Report
Community Expert ,
I think what you mean is how do you call the help so that a specific topic opens with the TOC and the toolbar instead of on its own with just Show. If so, see the topic on Calling Webhelp using URLs on my site.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
OMG if this works....
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
