3 Replies Latest reply on Dec 18, 2014 10:31 AM by PIM
    CF 11 Update 3 and CFCHART
    PIM Level 1
      We just upgraded to the latest build for Coldfusion 11 and our cfcharts are failing. The build is as follows 11,0,03,292480.
      I am getting this error:
      Error casting an object of type java.lang.Boolean cannot be cast to java.lang.String to an incompatible type. This usually indicates a programming error in Java, although it could also mean you have tried to use a foreign object in a different way than it was designed.
      The error occurred in C:/inetpub/wwwroot/cmis/e_survey/usage.cfm: line 141
      139 : <cfelseif ListFind("1,2",answers.s_qtypeid)>
      140 : <cfchart style="usage.json" format="png" chartheight="400" chartwidth="400" showborder="yes">
      141 : <cfchartseries type="pie" query="answers" itemcolumn="row_optionname" valuecolumn="total" />
      142 : </cfchart>
      143 : <cfelse>
      We have been required to put in the latest update due to the security vulnerability.
      Can someone help me on whether there is a newer version of the update or what I can do to fix this? It was working fine with Update 2.
      I have determined that the legend options in my json file for ZingCharts seems to be the problem but I do not know what.
      Phil Mervis
