• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
cf 11 install location
Explorer ,
Dec 17, 2014 Dec 17, 2014
I am trying to locate information on where Cold Fusion 11 should be installed.
Currently, CF 9 is installed on the C drive where IIS is and there are no issues.
I have replaced CF 9 with CF 11, but I have installed CF 11 on the D drive and having issues.
Should CF 11 be installed at the default location on the C drive?
Mike
Views
3.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Dec 19, 2014 Dec 19, 2014
I noticed in the web.confif file for the website the following:
I would think the wsconfig tool would change the entries.
Also below is the complete information in the web.config file:
Votes
Translate
Translate
Advocate ,
Coldfusion can be installed where ever you like (within reason). The issue you are having is probably related some something a lot different.
What are the issues you are having? Did you uninstall CF9 or just install CF11. Is it possible still are both running together?
Votes
Translate
Translate
Report
Report
Explorer ,
CF 9 has been uninstalled.
With CF 11 when the page initially loads the image appears. But when the page is refreshed the image disappears (there is a red x in place of the image).
I have applied all the latest updates for CF 11.
Mike
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Sounds like a connector issue. Can you recreate the connector (launching the tool as Administrator) and test the site?
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Explorer ,
After the updates, I executed the Web Server Configuration (As Administrator) and the issue still exists.
Mike
Votes
Translate
Translate
Report
Report
Advocate ,
Is this not the same as the issue you were having here?
Cold Fusion 11 refresh page image does not appear
HAve you done the things recommended in that thread?
Votes
Translate
Translate
Report
Report
Explorer ,
I have been talking with the server admin and the option for adding Failed Request Tracing Rule is not available in IIS.
Currently, running IIS 7.
Mike
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Mike,
Failed Request Tracing Rule is available in IIS7. You just need to enable it. See here http://technet.microsoft.com/en-us/library/cc725786(v=ws.10).aspx
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Advocate ,
As mentioned it is available. In the post I made in that other thread I mentioned "If its not there then you will need to run the server management and add it to the IIS role on the server." You will need to get your server admin to do this.
Your best bet will be to get that on there and trace the 500 error.
Votes
Translate
Translate
Report
Report
Explorer ,
I had to install options for the Health and Diagnostics section in IIS for the Failed Request Tracing to appear in the Actions pane.
When I enter the following in the command window (Replacing the site with the URL, int with 50 and string with 404
appcmd configure trace " site " /enablesite /directory: string /maxLogFiles: int
The received is the following:
'appcmd' is not recognized as an internal or external command, operable program or batch file.
Mike
Votes
Translate
Translate
Report
Report
Advocate ,
Try following the instructions I posted here Re: Cold Fusion 11 refresh page image does not appear
It uses the GUI built into IIS and might help you a bit more.
Votes
Translate
Translate
Report
Report
Explorer ,
The Failed Request Tracing Rules icon does not appear in IIS.
Mike
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Try IISRESET, in command prompt (run as admin) and refresh IIS Manager after that.
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Explorer ,
I had the server rebooted and then the Failed Request Tracing Rules icon appeared in IIS.
I setup the trace and below are the results:
Security Denied by ISAPI Restrictions
ImageNameC:\JRun4\lib\wsconfig\1\jrun_iis6_wildcard.dll
NOTE: This directory does not exist on the server
Module Set Response error Status                                    IsapiModule
ModuleNameIsapiModule
Notification128
HttpStatus404
HttpReasonNot Found
HttpSubStatus2
ErrorCode2147943660
ConfigExceptionInfo
NotificationEXECUTE_REQUEST_HANDLER
ErrorCodeThis program is blocked by group policy. For more information, contact your system administrator. (0x800704ec)
Votes
Translate
Translate
Report
Report
Guide ,
That looks like holdover garbage from your CF9 installation.  That should have been flushed out when IIS was removed and reinstalled.  Since it hasn't been, you're going to have to manually find this and delete it.  It's in either that site's handler mappings or in the main IIS handler mappings.
-Carl V.
Votes
Translate
Translate
Report
Report
Advocate ,
Dec 18, 2014 Dec 18, 2014
This looks like the DLLs left over from your previous CF9 installation.
If you look in the IIS Management Console under ISAPI and CGI restrictions (This is in the root of IIS, not your virtual site) do you see any "Macromedia Server Extensions" references DLLs from the old CF9 install?
If so it will probably be worth removing them. The only one you should have in there for a CF11 install is "tomcat_All" which points to a isapi_redirect.dll. If you don't see this either I would re-run the Web Server Configuration Tool (As Administrator) as this should restore it or worse case you could try adding manually. The default is shown here:
If you have followed the lock-down guide at all you will need to make sure you have applied the correct permission to these folders too.
Votes
Translate
Translate
Report
Report
Explorer ,
In the ISAPI and CGI Restrictions in IIS, I see the following:
D:\ColdFusion9\runtime\lib\wsconfig\2\jrun_ii6_wildcard.dll
The entry does not have a description.
Also, there is an entry in the ISAPI and CGI Restrictions for tomcat_All.
Should the entry for the ColdFusion9 be deleted?
Mike
Votes
Translate
Translate
Report
Report
Adobe Employee ,
  1. Remove the connector.
  2. Refresh IIS and delete handlers for cfm, cfml, cfr, cfswf, cfc (look both at Server and website level).
  3. Try IISRESET, in command prompt (run as admin) and restart IIS Manager after that.
  4. Recreate the connector
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Explorer ,
Connector has been removed.
The identified handlers have been deleted.
Cannot find the IISRESET.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
IISRESET has to be typed in command prompt (run as admin). This command is to restart IIS. You can restart IIS from IIS manager or from windows services as well.
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Explorer ,
IIS has been restarted.
I removed and re created the Web Server Connector.
Now when executing the web page, getting a 404 error.
Noticed in the ISAPI and CGI Restrictions the entry for tomcat_All is missing. I added the tomcat_All.
Still getting a 404 message.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
What is the url and what is the output. Please share the screenshot.
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Advocate ,
You usually get a 404  because the handlers are not set-up correctly for the website. For example if you add a new virtual directory without running the web connector. Recreating the Web connector should recreate the tomcat_All DLL. As you said it wasn't there it probably wont have done the other parts correctly.
Remove the web connector, restart IIS and then add it back, make sure you add it to all the sites you have there. You should see the command prompt window showing it being added.
If this is still not working then under the virtual directory of your site, go into handler mappings and use the "Revert to Parent" option on the right hand side. You can do this for the ISAPI filters too.
Votes
Translate
Translate
Report
Report
Explorer ,
I manually deleted the entry from the ISAPI and CGI Restrictions.
I restarted IIS.
I manually added the entry from the ISAPI and CGI Restrictions.
When I executed the web connector, there were no messages in the command window.
Also, there is no "Revert to Parent". Only "Revert to Inherted".
Votes
Translate
Translate
Report
Report
Adobe Employee ,
After manually deleting the mappings, you need not to recreate the connector manually. Please delete the manual entries, you have added.
Run the wsconfig tool with admin rights and then only create the connector. The tool is sufficient enough to add the necessary mappings.
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Resources
Documentation
