• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Flash Player download keeps failing with lost connection and then gives up. satellite Internet connection
Guest
Dec 17, 2014 Dec 17, 2014
Win XP. Firefox 34.0.5 (latest)
The Flash  Player download keeps failing with lost connection and then gives up.I am on a  satellite Internet connection.
It seems to be extremely slow even when loading the installer which is only 1MB. Then when I run the installer and it starts to download the installation there are frequent messages about losing the connection and then finally gives up.
I have had problems with other software failing when I am on a satellite link. This is most likely because of the huge latency which may be taken as a link failure. Ping times are typically 800ms but can be 2000ms sometimes!
Views
267
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Dec 17, 2014 Dec 17, 2014
Hello,
The online shim installer, which you are using actually downloads and installs Flash Player silently in the background.  If your satelite connection is experiencing latency issues it could result in the failure to download.  Please try the full installer posted at the bottom of the Installation problems | Flash Player | Windows page, in the 'Still having problems' section.
Maria
Votes
Translate
Translate
Adobe Employee ,
Hello,
Maria
Votes
Translate
Translate
Report
Report
Guest
Thank you!
This worked without any problem.
Votes
Translate
Translate
Report
Report
Guest
LATEST
This problem should be included in a FAQ.
There are at least 100 thousand people in Australia alone  with satellite connections who probably have the same problem.
Votes
Translate
Translate
Report
Report
