2 Replies Latest reply on Dec 17, 2014 10:53 PM by Bob Somrak
    image resizing question
    michellelynn18
      Could you let me know how to resize to these exact requirements in Lightroom for real-estate phot purposes. thanks!  Dimensions: 640x480  Type: JPG  File Size: 32K
      thanks
        • 1. Re: image resizing question
          ~IanB~ Level 1
          thats very small
          click export and there are two panels that set sizes>> file setting and image size.
          you may need to play around with some test exports to get 32K
          once you have it sort save it as a preset
          You may need to crop file before hand BTW
          yell if that doesn't make sense
          • 2. Re: image resizing question
            Bob Somrak Level 6
            First of all, crop the photo to a 4X3 aspect ratio which is 640X480.  Lr's std crop panel shows 1024X768 which is the same ASPECT RATIO so just choose it.
            After cropping, set the export dialog as follows.   It may not be exactly 32k but should be close or at least smaller.
            Due to a bug/glitch, you may not get EXACTLY 640X480 and may be a pixel off in one of the dimensions but probably not a problem for a realestate photo.
