5 Replies Latest reply on Mar 14, 2007 2:05 PM by Peter Grainge
    Trying to access INDEX shuts down RoboHTML
    Deb_Lipp Level 1
      I see this issue was brought up
      http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=65&catid=451&threadid =1232430&highlight_key=y&keyword1=index">here[/L] but no response was ever posted.
      This same thing is happening to me this morning, after successfully using the index yesterday. Can you help??
        • 1. Re: Trying to access INDEX shuts down RoboHTML
          Try having just one index work not in a topic.
          • 2. Re: Trying to access INDEX shuts down RoboHTML
            Linux Rules Level 2
            Hello DebLipp -
            Happened to us some time ago, too. I traced the root cause to a corrupt ".hhk" file (it holds index data; ours is over 50,000 lines long). I found a corruption where a CLOSE statement was trashed. I manually fixed that and the index was restored.
            It should look something like this:
            <html>
            <!-- Sitemap 1.0 -->
            <object type="text/site properties">
            <param name="SiteType" value="index">
            </object>
            <ul>
            <li><object type="text/sitemap">
            <param name="Name" value="{name}">
            <param name="Local" value="{location\name.htm}">
            </object>
            </object>
            <ul>
            </object>
            </ul>
            >>>>>>>>>>>> Lather, rinse, repeat <<<<<<<<<<<<<<<<<
            </ul>
            </html>
            Take a look at your hhk file as it may be at fault.
            Regards,
            GEWB
            • 3. Re: Trying to access INDEX shuts down RoboHTML
              Deb_Lipp Level 1
              quote:
              No idea what you mean.
              • 4. Re: Trying to access INDEX shuts down RoboHTML
                Deb_Lipp Level 1
                Thanks, but the hhk looks healthy.
                Somehow, moving the entire project to a new folder got me up and running.
                • 5. Re: Trying to access INDEX shuts down RoboHTML
                  Sorry, I wrote that stone cold sober. Now I've been out for a lovely meal and knocked back some wine. So , what I meant to say was
                  Try having just one index worD not in a topic.
                  We had a post a while back where someone had an index problem that was fixed with that trick.
                  Glad you got the show on the road.
