3 Replies Latest reply on Dec 18, 2014 8:29 PM by Adobe-InDesign CS4
    adding script into menu bar
    VeluVK Level 1
      I have some scripts in each projects. I need to run one by one base on the project. Can i have any option to add this scripts into menu bar?
      Please suggest.
      Regards,
      velu
        • 1. Re: adding script into menu bar
          Adobe-InDesign CS4 Level 1
          Dear Velu
          //============================ Script Start ===================================//
          var tableMenu = app.menus.item("$ID/Main").submenus.item("Table");
          try {
          var subMenu = tableMenu.submenus.item("Floating Tables");
              subMenu.title;
          catch(err) {
          var subMenu = tableMenu.submenus.add("Floating Tables", LocationOptions.AT_END);
          var topLeftAction = app.scriptMenuActions.add("Top Left");
          var topLeftListener = topLeftAction.eventListeners.add("onInvoke", FloatingTablesHandler);
          var topLeftMenuItem = subMenu.menuItems.add(topLeftAction);
          //============================ Script End ===================================//
          Please Use the above code that will helps with you
          Thanks & Regards
          T.R.Harihara Sudhan
          • 2. Re: adding script into menu bar
            VeluVK Level 1
            Hi Hari,
            I will try this. Thank u for the script.
            Regards,
            Velu
            • 3. Re: adding script into menu bar
              Dear Velu
              Please try one more method of the Menu Action:
              //=============================Script Start =============================//
              var mySampleScriptAction = app.scriptMenuActions.add("First Script");
              var myEventListener = mySampleScriptAction.eventListeners.add("onInvoke", function(){alert("This menu item was added by a script.");});
              //If the submenu "Script Menu Action" does not already exist, create it.
              try{
                  var mySampleScriptMenu = app.menus.item("$ID/Main").submenus.item("NewMenu");
                  mySampleScriptMenu.title;
              catch (myError){
                  var mySampleScriptMenu = app.menus.item("$ID/Main").submenus.add("New Menu");
              var mySampleScriptMenuItem = mySampleScriptMenu.menuItems.add(mySampleScriptAction);
              //============================== Script End ===============================//
              Thanks & Regards
              T.R.Harihara Sudhan
