3 Replies Latest reply on Dec 18, 2014 7:22 AM by rezun8
    clicktag not read
    EvaMartin
      Hello !
      I think my problem may be simple, but this gives me headache ...
      I've done several banners and want to add a simple clicTAG in it.
      in working on AS3, with flah CC.
      I've done a transparent object called "button", and converted it as a ...button.
      i tried several pieces of codes, but nothing worked well. The webmasters that should embed the SWF files gave me that :
      button.addEventListener(MouseEvent.CLICK, clickTagLaunch); function clickTagLaunch(e:MouseEvent) {           if(root.loaderInfo.parameters.clickTag != null)        {               navigateToURL(new URLRequest(root.loaderInfo.parameters.clickTag), "_blank");        } }
      But when I test the file, it always appears that no  clicktag is found (tested on Adops Tools | Home and test.adform.com)
      i'm exporting my swf on flash player 10.3
      I can't find any error in this code, do you people see anything ? If it's not the code, then i must have a publishing setting problem, or something like that, but I can't find what ... Please help !
      Thank you
        • 1. Re: clicktag not read
          rezun8 Level 4
          Hello Platypus
          try this code for AS3.0
          //CLICK TAG
          function handleClick(mouseEvent:MouseEvent):void {
              var interactiveObject:InteractiveObject = mouseEvent.target as InteractiveObject;
              var li:LoaderInfo = LoaderInfo(interactiveObject.root.loaderInfo);
              var url:String = li.parameters.clickTag;
              if (url) {
                  if (ExternalInterface.available) {
                      var userAgent:String = ExternalInterface.call('function(){ return navigator.userAgent; }');
                      if (userAgent.indexOf("MSIE") >= 0) {
                          ExternalInterface.call('window.open', url, '_blank');
                      } else {
                          navigateToURL(new URLRequest(url), '_blank');
                  } else {
          clickTag_btn.addEventListener(MouseEvent.MOUSE_UP,handleClick);
          • 2. Re: clicktag not read
            EvaMartin Level 1
            Mmmmh, i tried, thank you rezun, but it still does'nt seem to work.
            I've tried several codes, incuding this one (but I tried again, who knows )
            I Replaced at the last line "clickTag_btn" by my button name.
            Maybe the problem is on the publishing parameters ? here are mine :
            or maybe the button should not be a simple button ? Maybe there is something else to do but converting it as a symbol ?
            • 3. Re: clicktag not read
              rezun8 Level 4
              go ahead and PM me the file and i'll take a quick look at it, My thoughts are that the naming of the buttons might not be correct.
              send it on over
              Thx
              R
