0 Replies Latest reply on May 7, 2006 11:09 PM by am2605
    Indexing PDFs - Coldfusion 6.1 on Solaris
    am2605 Level 1
      I have an issue which I believe is similar but not identical to the following - http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_18517
      Where I'm confused is that I believe I'm using the workaround as described in the above technote - ie. i have set extension=".pdf":
      Here's an example of the code I'm calling:
      <cfindex
      collection="Master"
      action="update"
      type="path"
      key="/path/to/pdfs"
      urlpath="/pdfs"
      recurse="no"
      extensions=".pdf" >
      I thought it might have something to do with some of the pdfs being encrypted but I am not certain (I retried without the ones that I thought were encrypted and still got the error). This is all that appears in the cfserver.log:
      Server default ready (startup time: 8 seconds)
      java.lang.NullPointerException
      at jrun.servlet.jrpp.ProxyEndpoint.parseHeaders(ProxyEndpoint.java:807)
      at jrun.servlet.jrpp.ProxyEndpoint.readRequest(ProxyEndpoint.java:270)
      at jrun.servlet.jrpp.JRunProxyService.swapRunnable(JRunProxyService.java
      :144)
      at jrunx.scheduler.ThreadPool$DownstreamMetrics.swapRunnable(ThreadPool.
      java:320)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.swapRunnable(ThreadPool.jav
      a:433)
      at jrunx.scheduler.ThreadPool$UpstreamMetrics.swapRunnable(ThreadPool.ja
      va:280)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:76)
      ReadHeadersanddata: save by type.
      Readfiles in path: ::
      Readfiles in path:
      autorestart: Restarting process
      Starting Macromedia JRun 4 (Build 75991), default server
      What am I doing wrong? Or is indexing PDFs in CF 6.1 not a good idea?
      Any help much appreciated.
