1 Reply Latest reply on Dec 18, 2014 3:15 PM by George_Johnson
    MailDoc() Adobe XI Pro
    dunkaholic54
      I am new to this and have search endlessly it seems, but I have created a form via formscentral.  It has been saved to my PC so that I can manipulate the form a bit with Javascript.
      Currently I am trying to add a button that emails the partially complete form to a group mailbox where someone will open, complete and officially submit the form using formscentral.
      I get the following error:
      RaiseError: An unimplemented or obsolete function was called.
      Doc.mailDoc:1:Field Submit to QC:Mouse Up
      ===> An unimplemented or obsolete function was called.
      I have been working with code posted on another forum and manipulating it to work for my instance, no luck.
      // This is the form return email. It's hardcoded
      // so that the form is always returned to the same address.
      // Change address on your form to match the code below
      var cToAddr = "formsAdmin@BigCorp.com"
      // First, get the client CC email address
      var cCCAddr = this.getField("ClientEmail").value;
      // Now get the beneficiary email only if it is filled out
      var cBenAddr = this.getField("BennyEmail").value;
      if(cBenAddr != "")
      cCCAddr += ";" + cBenAddr;
      // Set the subject and body text for the email message
      var cSubLine = "Form X-1 returned from client"
      var cBody = "Thank you for submitting your form.\n" + "Save the filled form attachment for your own records"
      // Send the entire PDF as a file attachment on an email
      this.mailDoc({bUI: true, cTo: cToAddr, cCc: cCCAddr, cSubject: cSubLine, cMsg: cBody});
      Any help is appreciated.
      --Michael
