3 Replies Latest reply on Dec 18, 2014 8:23 PM by A.T. Romano
    Timeline plays low quality verisions of my photos
    eriktydinger
      Hello guys.
      I can give you all info about my PC and how I did to put the photos in, the camera I used.
      But really, this must be able to be solved without this.
      This looks like an extremley basic problem that is just outrageous.
      Its a high quality PC, I use Premier Elements 13, normal 500 GB drive (no SSD) I only use 1 hard drive. Plenty of space on it.
      newly installed Elements 13.
      Okay. This is what I did.
      I started with adding some basic text, intro the the video.
      Then I "dragged" a high quality JPG file photo in.
      The photo looked as great as in the camera or in "windows previewer" etc.
      A nice quality photo.
      Then I started the playback, and Elements made the photo look like it had been taken with a potato.
      And a "hint" apperad slightly above the low right corner. I dont use Elements in English so Ill try to translate it for you:
      It said "playback". "click here to get an even high quality playback of your video" something like that.
      I pressed it and It didnt help at all. Still poor quality.
      Although, the photos look in normal quality when its paused, I dont playback.
      So basically. Low photo quality when doing the playback of the video.
      Its normal JPG files, I drag them in from a folder.
      Newly installed, no advanced settings or anything.
      Surely this must be an easy problem to solve a lot of people have came across?
      Thank you
      IMPORTANT EDIT:
      photos look great/normal quality when the video is rendered, i did this as a test.
      But it is still a bit annoying that they look so bad when editing.
      Its easier to work and see the final result before its rendered.
      Thread moved from Premiere Pro forum to Premiere Elements.
        • 1. Re: Timeline plays low quality verisions of my photos
          shooternz Level 6
          Playback with your Source and Program Monitors set to Full Rez
          • 2. Re: Timeline plays low quality verisions of my photos
            A.T. Romano Level 7
            shooternz
            Just to point out to others reading this thread....apparently this thread was initially posted to the Adobe Premiere Pro Forum with a Premiere Elements 13 question.
            And, under the circumstances, you appear to have offered a Premiere Pro answer to a Premiere Elements question. And, there are differences in this instance.
            ATR
            • 3. Re: Timeline plays low quality verisions of my photos
              A.T. Romano Level 7
              eriktydinger
              Apparently you have answered your own question by finding that Timeline rendering was needed to give you the best possible preview of the playback of that Timeline content in the Edit area monitor. If the program is indicating that you need the Timeline content render to get the best possible preview, you render. The preference for "Timeline Render Quality (valid for HD projects)" is not a substitute for Timeline rendering.
              Some just in case comments...
              Some considerations.....
              1. If your source media properties and the project preset match, then your import will come into the project with no colored line over it. This is the program telling you that you are seeing the best possible preview of those source media at playback in the Edit area monitor. No Timeline rendering is needed nor possible. But, each type you edit that import, then the program will tell you to Timeline render to get the best possible preview and will tell you that, orange line (needs rendering) and green line (rendering complete).
              2. You do not have to do this type of rendering. It is a preview matter. But, as you know, it is your window of opportunity to catch a problem sooner than later and is particularly useful when trying to determine what you have when working especially with titles, effects, transitions, and non native formats.
              3. A particularly disturbing event is when you save close a project with a rendered Timeline and you re-open it to find it with "unrendered" look (orange line over its content instead of the last seen green line over its content).
              Other considerations
              1. Is your Timeline exclusively photos or is it a mix of video and photos?
              2. No matter how high the resolution of the photos, their resolution in the end product will be determined by the end product format. Just how many
              oversized for the project photos you can use will be determined largely by your computer resources.
              3. Not sure it will factor into what you are doing, but, if your Timeline content (photos) destination is DVD-VIDEO on DVD disc, the photos appear
              sharper in the end product when a 1920 x 1080p DSLR project preset is established before import of the source media.
              If you find all of that unacceptable, you have purchased from Adobe direct, and are within 30 days of purchase, you can explore with Adobe details of
              return/money back. We are not Adobe here. Rather user to user forum.
              We would glad for the opportunity to discuss with you any of the above further.
              Please consider.
              Thank you.
              ATR
