0 Replies Latest reply on Dec 19, 2014 5:43 AM by andriichumak
    Resolve anchored object position with ExtendScript
    andriichumak
      I think this is a bug in inDesign ExtendScript API. If you try to run "resolve" method on anchored object it would always return you a coordinates relative to object's own left bottom corner.
      Steps to reproduce:
      1. Create TextFrame, fill it in with placeholder text.
      2. Create a PageItem, for example rectangle.
      3. Anchor rectangle anywhere in text.
      4. Select rectangle and run the following script:
      app.activeDocument.selection[0].resolve(AnchorPoint.CENTER_ANCHOR, CoordinateSpaces.SPREAD_COORDINATES, false)[0];
      I'm expecting to get rectangle's center coordinates relative to spread's coordinates. If I would release anchor and run the same command again - the coordinates are correct.
      InDesign CC 2014.1 on Windows 7 pro sp1 x64.
      Please, advice how can I get anchored object's center coordinates in spread coordinates system.
      Andrii
