3 Replies Latest reply on Dec 19, 2014 9:12 AM by Ann Bens
    Repeated Frames at the end of clips
    Repeated Video frames
      I have a MacBook Pro with the adobe premiere pro cc 14, but I noticed this problem is CS6 also. The problem is this: Say I have two clips in the timeline that are connected (Clip A, Clip B).
      If I alter Clip B in anyway (change scale or position, or simply remove it from the timeline) the first frame of Clip B will remain at the end of Clip A. So, when I execute the playback function I can see a quick flash of Clip B at the end of Clip A.
      Here's what I've tried:
      I tried rendering the files--didn't work.
      I tried simply trimming the repeated frame off--didn't work.
      Here's what did work.
      There's a straight line that goes through every clip, I don't know what its called but I think it has something to do with the speed, I would drag that from say 100 to 96.55. The video would have the red render bar above it, and the repeated frame would disappear.
      HOWEVER, in my current project  I have serval repeated frames in a blank space where there are video clips, so the previous method can not work.
      What the heck!?!?!
