6 Replies Latest reply on Jan 23, 2015 8:32 AM by btempleton1982
    Test Extension Panel doesn't open
    btempleton1982 Level 2
      I have a test extension panel which is not working properly. The extension appears in the "Extensions" menu, but when the item is clicked, nothing happens.
      Here is the manifest:
      <?xml version="1.0" encoding="UTF-8"?>
      <ExtensionManifest ExtensionBundleId="com.test.test" ExtensionBundleName="test" ExtensionBundleVersion="1.0" Version="4.0">
        <ExtensionList>
          <Extension Id="com.test.test" Version="1.0"/>
        </ExtensionList>
        <ExecutionEnvironment>
          <HostList>
            <Host Name="ILST" Version="[18.0,18.9]"/>
          </HostList>
          <LocaleList>
            <Locale Code="All"/>
          </LocaleList>
          <RequiredRuntimeList>
            <RequiredRuntime Name="CSXS" Version="5.0"/>
          </RequiredRuntimeList>
        </ExecutionEnvironment>
        <DispatchInfoList>
          <Extension Id="com.test.test">
            <DispatchInfo>
              <Resources>
                <MainPath>./index.html</MainPath>
              </Resources>
              <UI>
                <Type>Panel</Type>
                <Menu>Hello world</Menu>
                <Geometry>
                  <Size>
                    <Height>400</Height>
                    <Width>400</Width>
                  </Size>
                </Geometry>
              </UI>
            </DispatchInfo>
          </Extension>
        </DispatchInfoList>
      </ExtensionManifest>
      Here is the index.html:
      <!doctype html>
      <html>
          <body>
              <button id="btn">Click me</button>
          </body>
      </html>
      Also, I set the debug flag in the com.adobe.CSXS.2.5.plist file to 1 and the log level to 6, but no log is being generated.
        • 1. Re: Test Extension Panel doesn't open
          lesavage Adobe Employee
          You are updating the wrong plist file. Please update com.adobe.CSXS.5.plist. you can refer to forum post https://forums.adobe.com/message/7032423 for further information.
          Lea
          • 2. Re: Test Extension Panel doesn't open
            I have found the right file now and added the PlayerDebugMode 1 line to it. The panel still does not open when the extension is clicked from the menu.
            • 3. Re: Test Extension Panel doesn't open
              mmmathur Level 1
              Couple of question before any conclusion.
              1. Did you create this extension using any CC Extension Builder. For example Extension Builder 3 or Brackets ?
              2. Is this a boiler plate code for extension Test? I have doubt because your manifest.xml does not have .jsx path included.
              3. Can you please post snap shot or your extension directory structure ?
              • 4. Re: Test Extension Panel doesn't open
                I used a text editor, no special tools.
                Code was copied and pasted from the docs. There were several errors with quotation marks and such not copying over correctly. There may be others I did not find. Do you see anything else? Or know where I can find code that is guaranteed error-free to test with?
                Directory structure is:
                /Library/Application Support/Adobe/CEP/extensions/test
                     /CSXS
                          /manifest.xml
                     /index.html
                That's it.
                • 5. Re: Re: Test Extension Panel doesn't open
                  mmmathur Level 1
                  I could observe few discrepancies in your directory structure snap shot and manifest.xml file.
                      Your directory structure should look like:
                      /Library/Application Support/Adobe/CEP/extensions/com.test.test
                      /CSXS
                            /manifest.xml
                      /index.html
                  Here is the manifext.xml file, replace this with your manifest.xml
                  <ExtensionManifest Version="5.0" ExtensionBundleId="com.test.test" ExtensionBundleVersion="1.0.0"
                    ExtensionBundleName="Test" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
                   <ExtensionList>
                    <Extension Id="com.test.test" Version="1.0" />
                   </ExtensionList>
                    <HostList>
                              <!-- Illustrator -->
                              <Host Name="ILST" Version="[18.0,18.9]" />
                    </HostList>
                    <LocaleList>
                    <Locale Code="All" />
                    </LocaleList>
                    <RequiredRuntime Name="CSXS" Version="5.0" />
                   <DispatchInfoList>
                    <DispatchInfo >
                    <Resources>
                    </Resources>
                    <Lifecycle>
                    <AutoVisible>true</AutoVisible>
                    </Lifecycle>
                    <UI>
                    <Type>Panel</Type>
                    <Menu>Test</Menu>
                    <Geometry>
                    <Size>
                    <Width>400</Width>
                    </Size>
                                      <MinSize>
                                              <Width>400</Width>
                                          </MinSize>
                                          <MaxSize>
                                              <Width>400</Width>
                                          </MaxSize>
                    </Geometry>
                    </UI>
                    </DispatchInfo>
                    </Extension>
                   </DispatchInfoList>
                  Here is the HTML file I used:
                  <!DOCTYPE html>
                  <html>
                  <head>
                  <meta charset="utf-8">
                  <title>Test</title>
                  </head>
                  <body>
                  </body>
                  </html>
                  Also please make sure your are opening this extension in Illustrator 18.0 or later.
                  Its working for me as above!
                  • 6. Re: Re: Test Extension Panel doesn't open
                    You got it! I changed the name of the extension folder and now it works great. Thank you very much!
