My developers want to know if Bootstrap (http://getbootstrap.com/css/) was used in the development of the Responsive HTML5 layout. The answer may determine whether we upgrade to version 11. Does anyone know?
The layouts don't use bootstrap. The layouts don't use any kind of CSS framework. It is entirely self-contained and optimised for help.
You can create a layout that does use it, there's nothing blocking it. But as Peter mentioned it, will require a thorough understanding of HTML and CSS. In my experience, most people take a look at what it entails and then hire me to do it 😉
For a seamless experience, I can think of a few options. You can create a bootstrap layout (or without bootstrap) to match
...Copy link to clipboard
No idea – shoot an e-mail to the RH tech team at tcs.support@adobe.com<mailto:tcs.support@adobe.com>
BTW – what difference does it make?
Thanks for the quick response and for the RH tech team links.
This is an issue for my developers since they want the Help displayed in a new Web application to perfectly match it--with a seamless look and feel. My developers think that this is more likely to be achieved if Bootstrap was also used in the development of RH 11.
Have you generated a sample of the HTML5 help for them to have a look at?
I currently have a 30-day trial version of RH 11 and I'm working in the Layout Customization window to create a skin that matches the Web application's css specs. If I can match the look and demo the layout for my developers, that may suffice.
Willam van Weelden may know the answer for sure but I am reasonably confident in saying Bootstrap was not used. It should be the case that if you can modify the layout.css and the layout pages in Project Setup that you will achieve what you want.
The CSS and the HTML is complex so you will need a high level of HTML and CSS knowledge if you want to make changes beyond those that can be achieved from the layout editor.
For a seamless experience, I can think of a few options. You can create a bootstrap layout (or without bootstrap) to match the design. You can also generate an XML layout and let your developers inforporate it into their application. I don't think any HAT has an output based on bootstrap.
Kind regards,
Willam
Thank you. That's what I needed to know.
