1 Reply Latest reply on Dec 23, 2014 10:11 AM by Carl Von Stetten
    The tag handler ftp does not have a setter for the attribute parserKey specified in the Tag Library Descriptor.
    cmorbitzer
      Hello!
      We updated our CF10 installation to Update 15 and now our cfftp tags are throwing this error. I made a one line file with the code below to reproduce the error. Is there a problem with the code, our installation, or is this a bug that should be reported? Thanks for your help.
      Chris
      The code:
      <cfftp action="open" connection="My_query" server="xxx" username="xxx" password="xxx" stopOnError = "No">
      The error:
      The stack trace:
      coldfusion.jsp.JRunTagLibraryInfo$NoSuchAttributeException: The tag handler ftp does not have a setter for the attribute parserKey specified in the Tag Library Descriptor.
          at coldfusion.jsp.JRunTagLibraryInfo.getPropertyType(JRunTagLibraryInfo.java:627)
          at coldfusion.jsp.JRunTagLibraryInfo.buildTagInfo(JRunTagLibraryInfo.java:585)
          at coldfusion.jsp.JRunTagLibraryInfo.getTag(JRunTagLibraryInfo.java:267)
          at coldfusion.compiler.NeoTranslationContext.findTagName(NeoTranslationContext.java:354)
          at coldfusion.compiler.NeoTranslationContext.isKnownTag(NeoTranslationContext.java:230)
          at coldfusion.compiler.CFMLParserBase.isKnownTagName(CFMLParserBase.java:655)
          at coldfusion.compiler.cfml40TokenManager.TokenLexicalActions(cfml40TokenManager.java:6720)
          at coldfusion.compiler.cfml40TokenManager.getNextToken(cfml40TokenManager.java:6586)
          at coldfusion.compiler.cfml40.getToken(cfml40.java:13039)
          at coldfusion.compiler.CFMLParserBase.isTrivialAngleBracket(CFMLParserBase.java:773)
          at coldfusion.compiler.cfml40.jj_3_1(cfml40.java:11242)
          at coldfusion.compiler.cfml40.jj_3_2(cfml40.java:11312)
          at coldfusion.compiler.cfml40.jj_3R_70(cfml40.java:11332)
          at coldfusion.compiler.cfml40.jj_3_99(cfml40.java:12237)
          at coldfusion.compiler.cfml40.jj_3R_97(cfml40.java:12554)
          at coldfusion.compiler.cfml40.jj_3_98(cfml40.java:12595)
          at coldfusion.compiler.cfml40.jj_2_98(cfml40.java:8083)
          at coldfusion.compiler.cfml40.cfml(cfml40.java:4545)
          at coldfusion.compiler.cfml40.cftry(cfml40.java:1198)
          at coldfusion.compiler.cfml40.cfml(cfml40.java:4562)
          at coldfusion.compiler.cfml40.cfif(cfml40.java:311)
          at coldfusion.compiler.cfml40.cfml(cfml40.java:4554)
          at coldfusion.compiler.cfml40.start(cfml40.java:4994)
          at coldfusion.compiler.NeoTranslator.parsePage(NeoTranslator.java:694)
          at coldfusion.compiler.NeoTranslator.parsePage(NeoTranslator.java:675)
          at coldfusion.compiler.NeoTranslator.parseAndTransform(NeoTranslator.java:428)
          at coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:370)
          at coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:147)
          at coldfusion.runtime.TemplateClassLoader$TemplateCache$1.fetch(TemplateClassLoader.java:436 )
          at coldfusion.util.LruCache.get(LruCache.java:180)
          at coldfusion.runtime.TemplateClassLoader$TemplateCache.fetchSerial(TemplateClassLoader.java :362)
          at coldfusion.util.AbstractCache.fetch(AbstractCache.java:58)
          at coldfusion.util.SoftCache.get_statsOff(SoftCache.java:133)
          at coldfusion.util.SoftCache.get(SoftCache.java:81)
          at coldfusion.runtime.TemplateClassLoader.findClass(TemplateClassLoader.java:609)
          at coldfusion.filter.PathFilter.invoke(PathFilter.java:101)
          at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
          at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
          at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
          at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
          at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
          at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
          at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
          at coldfusion.CfmServlet.service(CfmServlet.java:204)
          at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:303)
          at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
          at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
          at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:241)
          at com.intergral.fusionreactor.filter.FusionReactorCoreFilter.doRequestNoFilter(FusionReacto rCoreFilter.java:712)
          at com.intergral.fusionreactor.filter.FusionReactorCoreFilter.doFusionRequest(FusionReactorC oreFilter.java:341)
          at com.intergral.fusionreactor.filter.FusionReactorCoreFilter.doFilter(FusionReactorCoreFilt er.java:246)
          at com.intergral.fusionreactor.filter.FusionReactorFilter.doFilter(FusionReactorFilter.java: 121)
          at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
          at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
          at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
          at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
          at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
          at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
          at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
          at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:422)
          at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:199)
          at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.jav a:607)
          at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
          at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
          at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
          at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
          at java.lang.Thread.run(Thread.java:745)
