0 Replies Latest reply on Dec 22, 2014 12:21 PM by jwatkins90
    How do I configure a dynamic table with Data-Drop Down selections to store separate values?
    jwatkins90
      I am attempting to use LiveCycle to create an Order Form that uses an ODBC to a SQL database. When a user makes a selection, a separate column in the table references the "Item #" associated in the SQL table, and generates a corresponding barcode.
      My problem is that when I select an Item from the drop down list, all the items in the table change. What am I missing here to separate the rows as different line items? I tried adding a [*] to the end of the connection string, and that allows me to select different options but does not generate the "Item #" or "Barcode" field.
      The screenshot below shows the basic form. When I select any of the data drop downs, all of the Items change.
      I used the auto generated script for the "Add Row +" button shown below. Is this my issue? Or do I need to alter the way I'm setting up the Data Binding in for my Data Drop Down?
      this.resolveNode('Table1._Row1').addInstance(1);
      if (xfa.host.version <8) {
        xfa.form.recalculate(1); }
