1 Reply Latest reply on Dec 22, 2014 2:51 PM by gkaiseril
    Calculate days elapsed between two date fields
    LeonaB17 Level 1
      I need a script to determine the number of days elapsed between two date fields. I have searched the FAQ's for this topic but have not found an answer that works for me yet.
      DATE1 is begin date field with MM/DD/YY format, DATE2 is end date with MM/DD/YY format, and DAYSEL is the days elapsed between DATE1 and DATE2.
      I am not proficient with javascript so I would greatly appreciate if someone could tell me what I need to put on the calculate tab of DAYSEL to run this calculation.
      Any help much appreciated!
        • 1. Re: Calculate days elapsed between two date fields
          I would use:
          // common document functions;
          function GetField(cName) {
          // get field object with error checking;
          var oField = this.getField(cName);
          if(oField == null) app.alert("Error accessing field named " + cName + "\nPlease check that this is the correct field name.", 1, 0);
          return oField;
          } // end GetField function;
          function Scand(cFormat, cDateString) {
          // using format convert date string to date object with error checking;
          var oDate = util.scand(cFormat, cDateString);
          if(oDate == null) app.alert("Error converting date " + cDateString + " with format of " + cFormat + "\nPlease check date string and date formatting.", 1, 0);
          return oDate;
          } // end Scand function;
          // end common document functions;
          // custom calculation script;
          event.value = 0;
          var cDateFormat = "mm/dd/yy"; // format for date fields;
          var cStartName = "DATE1"; // field name;
          var nDiff = 0;
          var oStartField = GetField(cStartName); // get field object;
          if(oStartField != null && oStartField.valueAsString != "") {
          oStartDate = Scand(cDateFormat, oStartField.valueAsString); // convert date string to date object;
          var cEndName = "DATE2"; // field name;
          var oEndField = GetField(cEndName); // get field object;
          if(oEndField != null && oEndField.valueAsString != "") {
          oEndDate = Scand(cDateFormat, oEndField.valueAsString); // convert date string to date object;
          if(oStartDate != null && oEndDate != null) {
          nDiff = oEndDate.getTime()  - oStartDate.getTime(); //elapsed milliseconds;
          event.value = Math.floor(nDiff / (1000 * 60 * 60 * 24)); // elapsed days;
          // end custom calculation script;
          If needed you can put all the code in the custom calculation. The code includes error checking for wrong fields and bad date/time fields.
